how to disable acoustic mode in scsi hard disk
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Hi kianlie,
This is a feature of some HDDs in order to make them quieter. Unfortunately, because they work by reducing the speed of the drive (according to load), they can make some systems run slow. There are utilities available to turn this feature on and off (where supported), but you will need to get these from the HDD manufacturer's website.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
