How to disable "select entire field" when clicking with mouse?
ZPM
When clicking in a field with the mouse, it likes to select all the contents. Like this:
To edit some part of the field, I then have to click again to clear the highlight, then click on the spot where I want the cursor to be. Is it possible to turn off this highlighting/select-all feature so I can just place the cursor where I want it on the first click?
Ztruker
Don't think so. About the best you can do is place the pointer where you want it and double click.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB
    Seagate ST2000NM001 2TB
    Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot)
    Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
virtual6
Vista Pro
If you're referring to a Firefox address bar, this is more of a browser question rather than a Vista question.
Anyway, this "select entire field" behavior can be changed with a "about:config" setting.
Search for the two "SelectsAll" settings, and toggle the values as needed.
Ztruker
I didn't know that, works as you said, thanks.
Any way with IE?
    Windows 10 Pro X64
    16GB
    1920 x 1080 (HDMI)
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP 0A68h
    5GB
    ATI FireGL V3300
    Realtek HD Audio
    1920X1080
    50 Down, 10 Up
