OldGrantonian
In WinXP Home, I could examine the details of my BT Broadband internet connection (single user with USB connection) as follows:
Control Panel > Internet Options > Connections tab
Select a connection from the list. Click "Settings"
I then typed all the settings in a text file. So if I lost a connection, I could manually enter all the settings without needing to insert the BT installation CD.
I changed to Vista at the same time that I changed to Orange Broadband (4-user wireless). The connection was set up by CD from one laptop. The other laptop just connected itself by magic, using a LAN cable.
Can anyone tell me how to find the settings?
