Solved How to get rid of "Speed up browsing by disabling add-ons" in IE
wither 3
Does anyone know how to get rid of that message which comes up constantly in IE 9?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
townsbg
~~тσωηsвg~~
Click on the drop down and select don't disable. That stopped it for me.
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    N/A
Vistaar
That feature is called Add-on Performance Advisor. Clicking "Don't disable" keeps the notification away for 30 days (or until you install a new add-on), whereas clicking "Ask me later" only stops the notification for one day. The method I always used was to click "Choose add-ons" and then configure the delay threshold in the lower portion of the window that opens:
It is not necessary to wait until the notification reappears in order to adjust the threshold. In IE, make sure that the Command Bar is displayed (Brink has written about that: Internet Explorer Command Bar - Turn On or Off - Windows 7 Help Forums). Click on the Tools menu in the Command Bar and select Toolbars > Disable add-ons.
Home versions of Vista have no Group Policy GUI, so those are the only available options for average users. Disabling the notifications via Group Policy or the registry is discussed at How to Disable, but I haven't tried it. Of course this feature can be beneficial for average users who install add-ons (perhaps unwittingly) and later wonder why IE is so slow.
    Vista Home Premium x86 SP2
    HP Pavilion Elite m9150f
    Intel Q6600
    3 GB
    NVIDIA GeForce 8500 GT
wither 3
Thanks to both of you for your replies.
The procedure recommended by townsbg has never stopped it for more than a day.
I'll try the method provided by Vistaar for changing the threshhold and report back. I don't want to disable all my add-ons. I already selectively do that in the add-on section because some add-ons come in a package and I don't want to disable all of them in the package.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
townsbg
~~тσωηsвg~~
I don't have that option.
    Windows 7 Pro x64
    Mid 2010 iMac
    8 gb
    1 TB
    N/A
wither 3
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Vistaar
    Intel Q6600
    3 GB
Vistaar
I found this-
http://winsupersite.com/article/windows-7/internet-explorer-9-feature-focus-add-on-performance-advisor
It's perfect because it tells you how to do a registry edit to change the value. I changed the .2 value to 1 per the directions. We'll see how it works.
If you're comfortable editing the registry, then that should be another way to raise the delay threshold.
Since you're using IE 9, please tell me what happens if you go to YouTube ? BTW were you successful in installing IE 10 for Windows 7?
    Intel Q6600
    3 GB
wither 3
That was on my Vista system. I just tried it in Win 7 which has IE 10 and the applicable entry for changing the value isn't there.
This pretty much repeats what Vistaar said to do-
https://www.winhelp.us/internet-explorer-10.html
I also found a blog how to remove the advisor all together but don't want to go to that extreme.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
wither 3
Hi Vistaar-
Seems we were typing at the same time.
I haven't seen that message this morning so I can't verify if what townsbg said about the feature not being availabe is true.
Yes, I have IE 10 on my Win 7 system.
I have to reboot the Vista system for the change to take effect. I'll do that later and get back to you.
I'm curious about your question concerning YouTube. I've never had a problem with it.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Vistaar
It's a Google website, and their end-of-support policies are giving Vista users a hard time. When I try to open their home page using IE 9, I see the message I posted here: http://www.vistax64.com/browsers-mail/304336-my-vista-will-stop-receiving-google-chrome-updates-soon.html#post1405973. I was just wondering if all IE 9 users get that, or if it might be because Firefox or a specific IE add-on is detected. If you do see the message, do you also get that with IE 10?
    Intel Q6600
    3 GB
townsbg
~~тσωηsвg~~
I got you message on IE 9 but not FF. I was able to close it though.
    Windows 7 Pro x64
    Mid 2010 iMac
    8 gb
    1 TB
    N/A
Vistaar
Thanks for that. A little experimenting shows that clicking "No thanks" on the YouTube message only works if cookies are allowed in IE 9. You can however use their search engine and play videos without allowing cookies. I hope wither 3 will let us know if IE 10 is getting the same treatment. I suppose we're going off topic, but at least this is an IE 9 thread and there haven't been many of those lately.
    Intel Q6600
    3 GB
wither 3
I finally rebooted. When I go to youtube.com, I get this message-
[h=2]Oops, your web browser is no longer supported.[/h]YouTube works with a wide range of browsers. However, if you'd like to use many of our latest and greatest features, please upgrade to a modern, fully supported browser.
Find the latest versions of our supported browsers below.
This message is based on the the user agent string reported by your browser. Any extensions and plugins you have installed might modify the user agent string. We received:
Mozilla/5.0 (compatible; MSIE 9.0; Windows NT 6.0; WOW64; Trident/5.0),gzip(gfe)
If I click on No Thanks, youtube opens.
In IE 10, I get the message that-
You're using an older version of Internet Explorer that we'll soon stop supporting. Please update your browser to the latest version.
If I close that message, youtube opens.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Vistaar
Thank you wither 3 for the extra information about YouTube's reaction to older IE versions. The message you see in IE 10 is exactly what IE 9 users were seeing until Google recently turned up the heat. I see (or rather Google sees) that your Vista is 64 bit, and that you have Firefox installed. I relied on IE 9 for years, but I now think Firefox is the best browser for Vista.
    Intel Q6600
    3 GB
townsbg
~~тσωηsвg~~
I did not get it on IE 11 on 7.
    Windows 7 Pro x64
    Mid 2010 iMac
    8 gb
    1 TB
    N/A
wither 3
Vistaar- I finally got the message again in IE 10 on Win 7. I selected the Choose Add-ons and was able to change the delay to 1 second. Works like a champ. Thanks.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
