How to give file sharing permission to a specific user over lan??
taylormah
I have a home network implemented using workgroup. I want to share a folder on my vista pc with one other user over lan. I want to set it up like if that particular user clicks on the folder (under "Network"->"My PC"), he gets access, but if some other lan user clicks on the folder, it prompt for a password OR give any kind of error.
So far I have tried going to to-be-shared folder's security permissions and grant "Everyone" read persmissions, but then everyone over lan gets access to the folder contents. If I remove everyone, then that specific user I want to share folder with also gets blocked out. So far its all-or-none results for me. Someone suggested me to create a local account on my pc with the same username as the friend I want to share folder with, but thats little clumsy stopgap solution for me because then I would have to create a user on my pc for every person over lan who I want to share a specific folder with. Is there any other way to accomplish the desired results??
    T7500 @ 2.2 GHz
    3GB
    Nvidia 8400M GS
    250Gb @ 5400 RPM
nso5300
there are a couple of ways you could make it happen but they all involve extra time and or money:
1) set up as NAS system some of the like the buffallo drive will allow you to create users to access network resources
2) use a open source ldap implentation to create a directory
3) set up a win srv 2k3/8 directory
without a directory there is no way to centerlly manage users and ressouces thats why setting
a cheap way would be if you have a extra pc and a large HDD you can´store all the profiles and shared folders on this pc
    Sony Vaio
    Intel Core 2 duo
    ATI Mobility Radeon™ HD 3400 Series
    1600x900
    400 GB
    Laptop
    DSL 2 Mbps in dec 16 yesssss
    We Can DO I.T.
