how to hide text
When using word, pre-Vista, under format -text I could "hide" highlighted text. I do not see how to do that in Vista and the help info is not helping.
TIA
Cheryl
Dzomlija
Resistance is Futile
TIA
Cheryl
I'm guessing you're using Office 2007?
The following screenshots show you how to hide text in a Word document:
Select the text you want to hide, then click the Show Dialog button under Home/Font
Add a check to Hidden, then click OK
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    2 x 80GB Seagate (I)
    2 x 120GB Seagate (I/S)
    2 x 200GB Seagate (I/S)
    2 x 250GB Seagate (I/S)
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
