how to install optional updates
springrobin
Hi
I have a Toshiba pc and it updates automatically. Recently I looked at it from control panel and there are 5 optional updates not installed so i went and listed all of them but there is no continuation? How do I install the optional updates? I did check the "recommended..." in the update portion regarding how you want Windows to update?
thanks
Joan Archer
Cross Stitch Queen
Does your machine need those optional updates, can you tell us what they were for ?
    Windows 10 Home
    HP 8312 (Socket FP4)
    Generic PnP Monitor ([email protected]) 512MB ATI AMD Radeon R5
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
rive0108
Optional updates do not automatically install.
They are usually language packs/games/etc. and have to be installed manually.
Optional updates are not considered to be critical/security issues.
You should check Windows updates periodically.
To remove optional updates you do not want or need, click it, and select "hide"
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    640GB 7200RPM SATA/RAID 0 (2x320GB)
    and 320GB 7200RPM External
    Wireless Microsoft 3000
    10 mbps/2 mbps
    Optical Drive:
    Panasonic UJ-220 DL BD-RE (Blu-Ray)
