Solved How to load the same /current internet explorer tab after minimize internet explorer?
Stuckfree
Is kind of annoying that each time I minimize internet explorer and the current tab or web page is not load as the current web page if I have many other internet explorer tab opened after maximize again. I have to manually move the mouse pointer to the right internet explorer tab and select it or press the tab button.
Is there anyway to load the current internet explorer tab after minimize and maximize again?
Regard,
Thanks.
    HP
    2 G
    HP
    2 G
    AMD
    REALTEK
Lottiemansion
Re: How to load the same /current internet explorer tab after minimize internet explo
Funny but it does do that on my system! 3 tabs open on different pages.
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
Allan D
Hello Stuckfree,
I would request you to try resetting the Internet Explorer and see how it goes.
Hope this helps!
Stuckfree
Hello Styckfree,
Hope this helps!
Hi Allan D,
yeah man it works.But do you know what cause that?
Thanks.
    HP
    2 G
    HP
    2 G
    AMD
    REALTEK
Stuckfree
Hi Lottie,
Do you know how to fix that?
Thanks.
    HP
    2 G
    HP
    2 G
    AMD
    REALTEK
Lottiemansion
Fortunately I have never had the issue & therefore not investigated it in any way, I just checked my systems operation. Sorry.
    40 Meg
Allan D
Hello Stuckfree,
Issue could have been due to corrupted settings in Internet Explorer and a Reset has helped us fix it.
