How to open this Forum in a reasonable size
xbigjohn
I' running Vista an a new HP Pavilion Laptop, with Firefox as my browser. Everything is falling into place, but when I open this Forum it is so small that I must Zoom in at least three times to get it large enough to read! I don't have this problem with anything else, that I know of. How can I get this site to open in readable size??
ripbox
Nerd
Vista Pro
there is a little drop down tab at the bottom left of this forum that may help
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    150GB Raptor HDD
    500GB Caviar HDD
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
Dwarf
The Contemplator
Hi xbigjohn and welcome to the forums :party:
To have the forums open automatically to the maximum size when you log in, you need to make changes in your control panel. Click on 'User CP' and in 'Your Control Panel' under the section 'Settings & Options' click on 'Edit Options'. On this page, scroll down until you come the section headed 'Miscellaneous Options'. There are a couple of options here that should be what you are looking for. The first is 'Message Editor Interface' and the second is 'Forum Skin'. I have these options set as follows: 'Enhanced Interface - Full WYSIWYG Editing' and '-- Vista x64 net full' respectively. Don't forget to click 'Save Changes' if you make any alterations to your settings.
Dwarf
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
johngalt
Antidisestablishmentarianist
The place where you changed it - when you clicked on it, it "dropped down" with a list, right?
Now you know what a drop down is.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
xbigjohn
Yes, and I knew what a drop down is. It was the information that was in the drop down that was not clear. Just forget it - its fixed now.
Thanks for your help=
BJ
