How to repair disk permissions
I removed all permissions of Authenticated Users for my C: drive (entire permissions).
What I did is as follows:
. Right click C:
. Properties
. Security
. Deny all permissions for Authenticated Users
Now I can not reach my drive, can not change permissions again, and can not restore permissions etc.
Even Admin account can not do anything.
What can I do? :)
P.S: Please do not ask me "why, why did you do such thing?".
Thank you
SIW2
There must be a way of changing these permissions using regedit - never done it myself , so I couldn't give you the precise steps.
You should also be able to sort it out through one of the following methods - try them in order - you may need to use Method Two in the first link :
http://www.vistax64.com/tutorials/91467-startup-repair.html
http://www.vistax64.com/tutorials/88236-repair-install-vista.html
http://www.vistax64.com/tutorials/117366-clean-install-full-version-vista.html
Hope this helps
SIW2
SIW2
Hi Angelo,
That permissions thing may prevent system restore from operating on C in the normal way .
It's worth trying , as you pointed out - as method two might work. If it doesn't work, he can proceed through the other steps in order.
SIW2
SIW2
Angelo, I wasn't correcting you , I was agreeing with you - what you suggested is a good first step - and it may well do the job ! I hope so. When I said Method two , I meant Method Two in the first link i.e. the one you had posted.
Hi Angelo,
...It's worth trying , as you pointed out - as method two might work.
However, just in case that doesn't work - I listed other links he may wish to try - including the first one - as the order in which he may like to try them.
Cheers
SIW2
#8
Thank you for your replies.
System restore is not working as expected. Second method may not also work (my friend tried with an failure, yet I will try, too). I hope the third one will work.
In MacOS there is a special tool to repair disk permissons. What about the Vista? Maybe any third party tools...
Thank again
