My Laptop is a Toshiba P200 satelite it came with a OEM Recory DVD
is one of those DVD that you supose to run automatic and it then Wipe out everything and clean install it acording to Toshiba thats the best way of doing it.
But what if i just want to repair some System file
I have a Corrupt Msdos when i acess it by running "Command" in start/run and Msdos open I can only navigate the drives
by typing Cd c:/ cd... etc
But as soon i try to run something else lets say Type DIR in C:/ it Freezes as soon i press Enter (i see a cursor blinking up and down and dont let me do anything)
I am sure some Msdos files must be corrupted or missing and the solution is to restore those files repair vista.
Do i realy have to Clean install Vista everytime because Toshiba havent included any repair disc only a Full clean installation DVD?
I explorer the DVD
and this is the files found in it:
05718XR.crc
05718XSP.swm
05718XSp2.swm
05718XSP3.swm
05718XSP4.swm
05718XSP5.swm
05718XV1.crc
bootmgr
setenv.ini
Folders Boot:
with subfolder Fonts
bcd
boot.sdi
etfsboot.com
Folder EFI with subfolder Microsoft:
Has another folder with BOOT inside it is Fonts folder and a Bcd file
HDDPREP folder:
has 2 folders Boot and sources
Boot has font folder bcd file , boot.sdi and etfsboot.com
sources has boot.wim file
Sources folder:
boot.wim
TOOL folder:
crtdll.dll
imagex.exe
vRecoFastCRC.exe
XcludeCRC.ini
zlibwapi.dll
Is there anything there that has a hidden recovery partition that can help repair MSDOS without having to format the PC
I explorer the DVD
05718XR.crc
05718XSP.swm
05718XSp2.swm
05718XSP3.swm
05718XSP4.swm
05718XSP5.swm
05718XV1.crc
bootmgr
setenv.ini
Folders Boot:
bcd
boot.sdi
etfsboot.com
HDDPREP folder:
Sources folder:
boot.wim
TOOL folder:
crtdll.dll
imagex.exe
vRecoFastCRC.exe
XcludeCRC.ini
zlibwapi.dll
