Solved How to restore damaged files
Barbee
Two years ago my computer crashed. I now have a new hard drive. I had Geek Squad put all my file on a disk, however, a few are damaged. These are genealogy files that took me years to compile. Most are Jpg images of newspaper articles and censuses. I see online a lot of repair programs but when I download them, they only recover one file and then you have to buy it. I would buy it but I can't afford fifty dollars! Are there any cheaper ones or a cheaper way to recover these two folders?:cry:
whs
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
    6 external disks 60 to 640GBs
Barbee
I downloaded Recuva and all it does it retrieve deleted stuff... my files are in a folder, they are jpgs and my programs that open them say they are not jpgs, but they are. They must be damaged and I need to fix them. I clicked on that folder and ran recuva and it said it found nothing... it was looking for deleted files not damaged ones.
Isn't Linux a network? I don't have Linux.
richc46
If you put the files on a new hard drive and they are damaged, they are lost, unless you pay for software that can fix the problem. If you had them on the same hard drive where they were originally loacated you could use shadow explorer, but not in this situation.
For future use:
ShadowExplorer.com - About
richc46
We dont give suggestions for paid software, but you may be able to Google.
Barbee
I did Google, but don't trust these sites. I'd pay $29 but not $49... my retirement social security won't stretch that far. They only allow you to do one file and then you have to pay. What if I buy it and it doesn't work?
richc46
It is because of questions like that, we dont suggest. The members would feel awful if we suggested something and you got ripped off. In regards to your question, I dont know.
whs
Linux is an Operating System and it is free. You can try this: Computer First Aid Using Knoppix
Note: Knoppix is just one version of Linux. There are many others. The most used is Ubuntu. When you download the .iso (Knoppix or Ubuntu), you have to burn it to a CD and then load from the CD reader.
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
