How to restrict drive access to single user?
njkemps
Running Vista Home . . . while searching how to restrict hard drive read/write access for a specific user, I encountered this, which looks like exactly what I'm looking for. Just one problem, though - when stepping through Option 1 - Vista Home doesn't appear to have a Group Policy Editor.
Since it appears this is a precondition for a single-user restriction, I'm stuck for the moment - what are my options?
Thanks -
    Dell Dimension E520
MilesAhead
Eclectician
I have this table for Windows 8.
Group Policy Search
You could search to see if the Vista setting is there.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
njkemps
Thanks for the quick response . . . to me this looks like Option 3 from the originally-linked page, which prevents all users from accessing the drive. (Forgot to mention that it's an internal data storage disk, not "C:\", and that I've already set it up to be invisible within "My Computer".)
On our XP machine we have a few folders with security at the user level (some have it, some don't) and I'm trying to extend this to our newer PC.
Thanks -
    Dell Dimension E520
MilesAhead
Eclectician
My inclination would be to go with the .reg fine downloads that restrict all drives. Make some backups(there is an excellent Registry backup tool called ERUNT) including system image to an external drive if possible. Then attempt to edit the .reg files to your purpose.
If you use a system imaging backup tool such as Macrium Reflect or another that uses WinPE then you should be able to restore your Registry if badly damaged, by booting the WinPE disc or usb and using the ERUNT restore. See the readme file that comes with ERUNT and especially the section how drive letters will be different when you boot a restore disc. It's just a simple matter of having a small text editor that will run from the restore disc or usb so that you can edit the batch file to set the correct drive letter.
As this is one of Brink's tutorials he will know more about it than I. He may have a suggestion more to the point or simpler to carry out.
Edit: In fact if I were you I think I would post a link to your thread here right at the end of the tutorial. It's not uncommon for questions getting a tutorial to work to be posted on the tutorial thread itself.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
townsbg
~~тσωηsвg~~
Thanks -
The vista "home" versions do not have group policy editor. Only Business, Ultimate, and enterprise have it. It's the same thing for XP and 7.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
njkemps
My inclination would be to go with the .reg fine downloads that restrict all drives/
Since it looks like what I want to do isn't up to Vista Home's inherent capabilities, I'm starting to think something a little cruder will work best - namely, to deactivate this data drive in BIOS and reactivate it only when it's needed. Can't get much more invisible than that.
I'll do that . . . on some boards posting in a thread that's been inactive for two years would be considered impolite, so that's why the new thread here.
    Dell Dimension E520
MilesAhead
Eclectician
Good netiquette. On Vista I think they take into consideration the activity is much lower. Also it is exactly the issue. Brink will scold me if I'm wrong. :)
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Brink
Staff member
mvp
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
