How to retain extended desktop (Multiple monitors) across start-ups?
sfwalt
I have a T61 Lenovo laptop with Mobile Internet 965 Express Chipset, Vista SP2. I have a second monitor, Envison, installed which I use to extend my desktop--laptop display on right, Envision monitor on left. Everything works just fine, however, whenever I shut down my system (sleep or hibernate or shut-down) and then power up again, the Envison monitor only displays my wallpaper and I need to re-establish it as my "extended desktop". This configuration worked fine under XP (with all the same hardware), but now it reverts back whenever I shut-down. Can this be fixed? Thanks.
Patonb
Weird.... Though i've not ran dual monitors on my laptop, just my desktop.
How are you connecting to the ENVISON monitor? vga or hdmi
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
sfwalt
I don't actually know the answer about HOW I'm connected--just a multi-pin plug into the side of my laptop. This used to work just fine when I was running XP, so I suspect that it is a problem with Vista. I can live with the work-around (i.e., re-establish the extended desktop every time I restart my system), but it's just perplexing??!! And annoying. Thanks for your interest.
Patonb
Okay.... thats a vga connection.
Hmmm, you know what... I googled and youre not alone. Most people solved it with a driver update.
According to cnet you have a quadro nvs 140 gpu
If you have the 32bit the drivers here: NVIDIA DRIVERS 260.99 WHQL
64bit is here: NVIDIA DRIVERS 260.99 WHQL
Try the new driver and see how it goes.
sfwalt
Patonb,
Thanks so much for your suggestion. I downloaded the driver as you recommended (32-bit version) but when I tried to execute it, during the "Checking System Compatibility" step I got the message: "Install cannot continue" and "The graphics driver could not find compatible graphics hardware". This is very frustrating, but I think that I will just have to live with re-establishing my extended desk top every time I start up. It's really not that painful, just check "personalize" and "Display Settings" and then drag the monitors to their proper positions. I can almost do it in my sleep at this point. I really appreciate your efforts on my behalf, thank you.
Walt
Patonb
Probably due to the large model selection, i got some misinformation...
Heres the drivers page from lenovo with the intel, and nvidia driver.. I'd give the intel one ago. Just click Video link in the list.
Lenovo Support - Drivers and software - ThinkPad T61, T61p
I know youre use to it, but you shouldn't need too.
