how to set a hard drive to delete everything on it on shutdown
is there a way for me to configure my 2gb internal flash drive to dump everything on shutdown? i made it my temp files colector
    Custom built Desktop
    AMD Phenom II X6 1090T Black Edition 3.2Ghz
    MSI 890FXA-GD70 AM3 AMD 890FX
    8GB Adata Gaming series 2.0 DDR3 1600
    MSI Twin Frozr 5830 X2 with MSI 5850 Crossfired
    Asus 19", Acer 17"
    1400x900
    OCZ Agility 3 60gb, 500GB F3 Samsung Spin point and 5 other HDD's
    850W OCZ
    NZXT Phantom
    2 200mm fans with 6 120mm fans
    Saitek 2
    Logitec G9
    Major AMD, ATI and MSI Enthusiast.
Hallo n/p, are you meaning your temp folder or your page file that you have moved to your flash drive?
The only way i know to clear a temp folder properly is to manually delete its contents which you can access from the Run command and type; %temp%
But i dont know if this command would work if your temp folder is on your flash drive, but you could just open it from your Computer explorer window.
If it is your page file that is on your flash drive & you want it to clear itself on shutdown, then this is the tutorial for you;
http://www.vistax64.com/tutorials/157323-virtual-memory-paging-file-clear-shutdown.html
Things might have changed but i tried this once with XP & it made for a long shutdown
    Hewlett Packard, compaq presario CQ60-305AU
    AMD Athlon QI-46 2.1 Ghz
    Wistron 303C
    2048 Mb DDR2 SD Ram
    NVidea GE Go Force 8200M G / 256Mb dedicated grapics memory
    MCP78S NVidea High definition
    15.6" High Definition Brightview Widescreen
    1336x768
    Toshiba MK2555GSX ATA
    Synaptics PS2/Touchpad
There is probably an easier way, and I will think about it, but first write a batch file to delete the contents of that drive letter. Then use the Group Policy Editor to write a log off script to run that batch file. Or you could add an event, there must be a shutdown event, to run your batch file again.
If you need more direct help, just ask.
Richard
    Dell XPS 420
    Stock Dell 0TP406
    4 gb (DDR2 800) 400MHz
    1600 x 1200 and 1280 x 1204
    1 x 640Gb (SATA 300)
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
    Dell XPS 420
    Stock Dell 0TP406
    1 x 1Tb (SATA 600)
    Stock PSU - 375W
    Dell XPS 420
    Stock Fan
    Dell Bluetooth
    120 kb/s
