How to Share files between xp and vista
brooke21
Sorry, but I can't find my unique situation. I just bought a gatway laptop with vista and also have another laptop with xp. I have a network set up. Both laptops can get on that network wirelessly and can get on the internet with both.
Now the PROBLEM, my xp laptop (wireless) sees the vista laptop (wireless) but the vista laptop doesn't see the xp laptop.
I have made the vistat laptop private and turned on all sharing. I also tried to double click the vista laptop icon(on the xp laptop) but got the error message (not authorized...).
What steps do I need to take to get the two computers sharing?
Are you allowing the computers through the firewalls, which do you use on the machines ?
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
i have the same prob.
on my notebook i have vista and on my desktop computer i have XP and sometimes i can see files on XP and sometime i can't.
btw my firewall is turn off,file sharing is on,password protected sharing is off and media sharing is on
Make sure that both computers are in the same 'workgroup.' (Found in computer properties). I had a similar problem and that helped.
    Dell Studio 15 Laptop
    Intel Core 2 Duo T8100 2.1 GHz
    3 GB
    256 MB ATI Mobility Radeon HD 3450
    15.4 WXGA w/ TrueLife
The two laptops are in the same workgroup, all vista file sharing is on, the connection is set to private but when I look at the network map (on vista laptiop) the only thing I see is the internet icon(the world) then the router then my vista laptop. How do I get my vista laptop to see the other laptop running xp (wirelessly)?
to improve discovery between vista and XP macines you may want to download and install the Link Layer Topology discovery service on the XP machines.
http://www.microsoft.com/downloads/...1D-EE46-481E-BA11-37F485FA34EA&displaylang=en
also typing \\xpcomputername\ into the vista start menu search bar should display the available shares on the XP machine "xpcomputername" even when they are not displayed in the network and sharing centre or the network tab
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    Samsung 32" TV
    Internal
    Crucial CT256MX100SSD1 256GB SSD,
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS 4TB
    68 MB Down 18.5 MB Up
Try to search for Network discovery in Vista's Help and Support and then look at "What is network discovery". There could perhaps be some clues there.
    Dell XPS720
    Intel Quad Q6600 2.40GHz
    4GB DDR2 800MHz
    Creative SB X-Fi Xtreme Gamer
    Dell 2407WFP-HC
    1920x1200
    NVIDIA 640GB SATA Raid 0 (2x320GB) (7200 rpm) for Vista,
    Intel X25-M G2 160 GB for W7,
    Maxtor OT III External HDD,
    WD Elements 1 TB External HDD
