How to View ALL properties of a File?
ruffy
Into my Videos folder, that Vista set up for me under my user name,
I moved some files from my video camera.
But I want all properties to appear - all at once - without having to go
to each file individually and look at its Details section.
In the HELP file, it says as follows:
To view all the properties
  1. The Details pane is convenient, but it doesn't show all of the properties that are associated with a file. If you need to see all the properties that are associated with a file, follow these steps:
  2. Open the folder that contains the file whose properties you want to see.
  3. Right-click the file whose properties you want to see, and then click Properties.
  4. Click the Details tab to see all the properties associated with this file.
The problem is ==> THERE IS NO DETAILS TAB !!! :mad: !!!
Frostmourne
Banned
Can you right-click the columns in windows explorer/my documents, choose add to column and then select the columns you want to appear that are in the details tab like size, metadata, date changed etc?
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
Imperfect1
And, adding to that, when you select the "More" tab (at the bottom of the list), you get approximately 280 additional details to select from!
    HP Pavillion dv5t (Gen. 1)
    1680 x 1050
    built in - HP
    max
