Howto customize search result columns
trailo77
Hi there, I am desperatly trying to change Vistas default search result columns.
Everytime I use the do a search, I change the coulmns to
"Name, Folder Path, Size, Type".
Unforunatly Vista only remembers my settings for the already changed folders. If I search a different/new folder it defauls back to "Name, Date modified, Type, Folder, Authors, Tags".
Where can I change the default columns? As I do not want to change the columns for each and every folder ...
I have already customizes Vista's default folder templates in "C:\Users\<username>\" , but this has no effect on the search result.
Customizing the searches in "C:\Users\<username>\Searches" has also no use, as theese are the saved searches.
Any help appreciated :-)
garysgold
Hi Trailo77,
Do a search in explorer, set up the columns the way you like. Click- organize menu/folder and search options. Select the view tab and click the Apply to Folders button. This should set all search windows to be the same. Worked for me.
Hope it works for you.
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    2-WD5000AAKS-500 GB
    WD 5000AAV-500 GB external
    MX Revolution
    Microsoft Comfort Curve
    Wacom Intuos 2 Graphics Tablet
    Experience Index=5.5
trailo77
Hi garysgold ,
thanks a lot for your answer. I works exactly the way I want it to. :)
I never had the idea of using the organize/folder and search options button.
I've already tried appying the settings using the folder options from the tools menu, but this applied to all my folders....
So, again - many thanks !
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
dagzag
Hi Trailo77,
Do a search in explorer, set up the columns the way you like. Click- optimize menu/folder and search options. Select the view tab and click the Apply to Folders button. This should set all search windows to be the same. Worked for me.
Gary
I have the same problem, but I dont understand your answer:o where do I find "optimize menu/folder"?
Thanks
Brink
Staff member
mvp
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
Brink
Staff member
mvp
Your welcome Dagzag. I'm happy to hear your problem is fixed.
    3 x 27" Asus VE278Q
    1920x1080
    Logitech MX Master
    Lumia 1520 phone
