HP dv9815nr Ethernet Driver
RonW
5
hey new to the forum as a result of this problem. i reinstalled vista ultimate on my laptop with the real deal of vista ultimate (i hate all that crap HP added), anyway ive got all my drivers loaded, but for some reason under device manager my ethernet controller is being listed under other devices and is exclaimed. ive tried looking for the proper drivers on HP's website, but i couldnt find them. ive tried installing ethernet controller drivers that i thought would work, but no dice.
the system carries an nforce chipset so its obviously some type of nvidia ethernet controller driver. can anybody help with this problem?
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
RonW
5
yeah ive seen those drivers, all of them are loaded witht he exception of the ethernet controller drivers, those drivers dont exist on that page. they used to have them on the page, but they no longer do.
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Hi Ron,
In 'Device Manager', what does it show if you expand 'Network adapters'? This might give a clue as to where we need to look for the missing device. I would suspect that it will be either 'Broadcom' or 'Atheros' as they are listed in the 'Driver - Network' section of the link I gave you in my previous post. I provide links to the main Web pages for both of these - you will have to browse the sites yourself to see if you can locate anything. If it shows anything different, please reply with full details of what it says.
Dwarf
Broadcom Corporation - Semiconductor Solutions for Bluetooth, Digital TV, Enterprise Switching, GbE, Wi-Fi, Cellular, GPS, WLAN, DSL, Cable Modems, Set-Top Boxes and VoIP
Atheros, wireless local area networking, wireless, WLAN, 802.11n, 11n, 802.11g, 11g, 802.11ag, 11ag, 802.11, Radio-on-Chip, Ethernet, Mobile, Bluetooth, GPS, Semiconductor, System Solutions
    Gigabyte IF233
RonW
5
well, i was able to get the problem solved, basically through more searching and a bunch of time, and the trial and error method. the correct driver was found within HP's website but not on the dv9815nr page. for anybody else that has this problem the correct softpaq through HP for the nforce ethernet controller is sp36213.
johngalt
Antidisestablishmentarian
3,921
Location
3rd Rock
Well, not necessarily - as dmex pointed out you have a choice between one of *two* different manufacturers when getting that system - so that driver worked for *you* and anyone with the same card as you, but will not work for people who have the other card.
    Windows 10 Insider Preview current build
    The Beast Model V
    eVGA X58 Classified3
    3 * 4GB Mushkin Enhanced Redline CL7 DDR3 1600 MHz (PC3-12800)
    eVGA GTX 970 + eVGA GTX 560 Ti 448 Core Classified (PhysX)
    Realtek HD Audio (onboard)
    2 * Lenovo LT2323pwA
    2 * 1920 x 1080
    SanDisk Ultra SDSSDHII-960G-G25 SATA III SSD (System)
    Crucial MX100 CT256MX100SSD1 SATA III SSD (User Tree)
    2 * Seagate Barracuda 7200.12 ST31000528AS SATA II
    Seagate ST1500DL001 7200 RPM SATA II
    Intel SSDSA2M080G2GC SATA II SSD
    ThermalTake BlackWidow 850W
    ThermalTake Level 10 GT
    Corsair H100 (CPU) + Air (2 * 210 mm + 3 * 120mm fans)
    Logitech MX Master
    Logitech G15 (gen 2)
    300+ Mbps downstream / 30+ Mbps upstream
    Windows 10 Insider Preview (current)
    Dell Inspiron 3521
    Intel(R) Celeron(R) CPU 1007U @ 1.50GHz
    Dell
    Intel(R) HD Graphics
    Intel(R) Display Audio | Realtek Audio
    Inspiron 15"
    1680 * 1050
    INTEL SSDSC2CW180A
    Dell
    Dell
    Dell
    Logitech MX Master | Synaptics TouchPad
    Dell
    300+ Mbps downstream | 30+ Mbps upstream
RonW
5
right, which is why i listed the model number of the laptop dv9815nr and the specific problem was an nvidia nforce ethernet controller, which that piece of software is specifically for. unless theirs another dv9815nr with another chipset and ethernet controller, but from my understanding it this specific model of notebook comes with an nvidia chipset with an nforce ethernet controller, and an atheros wireless card.
