HP Laptop Freezes, But Only When Idle
boweasel
My wife bought a refurbished HP Pavilion dv5 laptop recently (32 bit Home Premium), and although she's happy for the most part, there is one unfortunate characteristic she'd like changed - whenever she lets it sit for at least an hour it invariably freezes. It never freezes on her while she's in the middle of using it, but if she (say) reads and responds to her email and leaves the screen on her email list for an hour or so it will be completely unresponsive upon her return. No cursor. No Ctrl/Alt/Delete. She always has to hold in the power button to reuse the PC.
I've done full Malwarebytes scans, run TDSSKiller, run ComboFix. Set up and run chkdsk /f at boot. Everything looks okay. When I check the Event Log the only thing I can ever find are errors related to the non-sanctioned shutdown. But maybe I'm not looking in the right place.
I could use some advice on what tests or applications to run.
See if in the bios you can turn speedstepping/cool n quiet off.
I'm wondering if it downclocks and undervolts too low.
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
It sounds to me like the Power Mangement configuration is set to turn the system off after x minutes.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
