HP On-Screen Caps/Num/Scroll lock Indicator
khdphd
THE "HP On-Screen Caps/Num/Scroll lock Indicator" shows up in Programs and Features, but the size cell is empty!! Indicator lost during a previous "fix" of an unrelated problem. HP states they can neither replace the file nor download the file contenets. What, Where, and How can I retrieve the indicator as I have a &[email protected]*+ remote keyboard? HELP!
khdphd
johngalt
Antidisestablishmentarianist
Hi, khdphd, and welcome to the forum....
They say they cannot download the file? I have always seen every HP that uses those hkCMD.exe files to be able to download them for that computer in the event of a reinstall.
Did you look at software available for download for your computer? If it is there, then you can download it, uninstall the current version, reboot and install that one and it should load the original files back in place.
Try uninstalling hkcmnd from Programs and Features (it may be named something a bit more fancy)
And I know what HP *said* - but look anyway.
    The Beast Model V (homebrew)
    Realtek HD Audio (onboard)
    2 * 1920 x 1080
    Logitech MX Master (shared)
    Logitech G15 (gen 2)
    Lenovo ThinkPad E545
    AMD A6-5350M APU
    Lenovo
    Radeon HD (Embedded)
    Conextant 20671 SmartAudio HD
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
johngalt
Good luck to ya....
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
khdphd
The real question is why do computer makers and software writers charge so much, and force their customers to wait on the phone for hours and hours just to find out they have no knowledge of your problem, nor even an inkling of a "fix" that won't create another problem (which is usually more disabling)?
johngalt
Hmm - weird - I have never had to pay for online support....then again, I rarely ever have to call either, so that might be a factor....
    2 * 1920 x 1080
    AMD A6-5350M APU
    Lenovo
    Lenovo 15" Matte
    1680 * 1050
    Lenovo
    Lenovo
    Lenovo
    Lenovo
mansrm81
If you want it back click on start then scroll down to PC Help & Tools then click on Recovery Manager then click on Advanced options then dot the software program re-installation and look for On-Screen Caps/Num/Scroll lock Indicator and click next and it will install it back onto your computer. Also it will not show the size of the installation.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
