hp printer's problem
tammamisss
hi,
i have an HP deskjet f370 all in one, i dont have the driver CD of it, so i downloaded the driver from the official HP website but unfortunately it did not work, when i try to open it it says file corruopted.
-the file i downloaded is about 105 MB
-it is a EXE file
-it is downloaded from hp.com
-i have a windows vista ultimate 32bit
Can anyone please help me out????
    3.19 GHz
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
i actually dont know what sp2 is, and no, its not updated to sp2, but isnt it for windows xp and not vista???? so i need it???? actually the driver i downloaded is america, english, all in one so i dont know what the problem is, thanks alot for helping me, and i didnt expect fast replies at all.
    3.19 GHz
SP2 means Service Package 2. If you go to the link provided, you can download and install SP2-
vista sp2 - Search Microsoft.com
This will fix a lot of problems.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
Please post back results please..
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
following the link you gave me i found no SP2 downloads available for windows seven, so what do you want me to do in order of helping me solving my problem?
    3.19 GHz
? This is a Vista forum. I guess everybody, like myself, thought you were using Vista. I'm sorry if I'm a little surly but this is Vistax64.com.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
Windows 7 Forums Please use our sister site . and mark this thread as solved .. i guess.. Same users here are there. but are more experienced with Win. 7.. Thanks ..
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
You might also. want to give correct system specs .. as you clearly indicated here you were using Vista Ultimate .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
20 flogs with a wet noodle. :D
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI
    WDC WD20
    Apevia XJupiter
    air
    Logitech MX 3200
    Logitech MX 600
    30 Mbps
