I can't print because network drives disconnected.
A
Advice Pro
At startup, I got
Code:
Could not reconnect all network drives
There is a red X next to MEMQRYCARD (\\EPSOM5F09AO fZ:)
A
Advice Pro
I re-installed the drivers and can print now. I would still like to rid the X in my Computer and also notice that drive K won't appear for my memory card. I remember working on this before and I forgot exactly what to do. I went to Computer > Tools > Map Network Drive, at the Drive dropdown menu I select drive Z for my printer. Now what do I do?
townsbg
~~тσωηsвg~~
I believe if you right click on the x-drive from computer you'll have to option to remove it or disconnect.
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    N/A
    Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1440 x 900
    1 TB & 360 GB
