You should upgrade or use an
alternative browser .
i GET a dialog box ARMY with properties
when is start my vista, a it opens i get this dialog box which has army written on the title bar and properties, 0 files,o folders and a restore button,wat is this?a type of virus ?malware ?
http://img25.imageshack.us/i/76561717.jpg/
Eye know, eye know
It's suspicious whatever it is. Don't press restore.
Run some a/v and malware scans.
i7 3770K HT ON 4.7GHz
P8Z68 Deluxe Gen 3
8GB G.Skill Ripjaws X 2133mhz
X-FI Forte + ATH-AD900
1920*1200 / 1920x1080
Corsair AX1200W
Lian Li PC-V1020A
Laptop Specs:
Clevo Sager P170HM //
17.3 Matte 1920x1200 //
i7 2720QM // 8GB 1333mhz //
Dedicated GTX 485M //
Samsung Story 2TB USB 3.0
i ran every sacn with every program but cudnt find a thing
Eye know, eye know
Using regedit, check your run keys in the registry for suspicious entries:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run
Using msconfig, check the startup tab for suspicious entries:
Have you recently installed any new apps/games? ie America's Army etc
P8Z68 Deluxe Gen 3
Corsair AX1200W
Lian Li PC-V1020A
Laptop Specs:
no i did no install america's army ,
i ran regedit and i deleted an entry for army.exe.. i hope it works
Eye know, eye know
No worries
P8Z68 Deluxe Gen 3
Corsair AX1200W
Lian Li PC-V1020A
Laptop Specs:
