You should upgrade or use an
alternative browser .
I have NO Idea what kind of display driver I have
Recently my display driver crashed with the "nvlddmkm.sys" problem so I had a new display driver installed. The only problem is that I have NO IDEA what kind it is. I took it out and searched for a logo but I couldn't find anything. My OS is Windows Vista Home Premium 32bt. Please Help!
Windows
Pentium Dual Core
2046 MB, 3GB
GeForce 8400 GS, Intel Graphics Media Accelerator 4500MHD
HP w17e
1400x900
If you're going through hell, keep going
Operating System
Win 10 Pro x64 x 2
Alienware ALX x58
2 x 500gb SATA II
1 x 1TB SATA II
1 external eSATA LaCie 3TB
(Non-RAID)
Unique
1gb/s up and down
The Belarc Advisor worked perfectly but it said I have a Standard VGA Graphics Adapter which was the configuration for my old graphics card. My computer works fine but when I need the graphics, it'll give me a "grapics failed to initialize". So I need the driver software for this new card which I don't know anything about.
Windows
Pentium Dual Core
2046 MB, 3GB
HP w17e
1400x900
Maybe CPU-Z might give more info?
CPUID
Also if set that way Windows Update may have at least the basic driver needed by automatically detecting it.
Operating System
Win 10 Pro x64 x 2
Alienware ALX x58
2 x 500gb SATA II
1 x 1TB SATA II
(Non-RAID)
Unique
1gb/s up and down
hmmm im not sure i want to do any more downloading on this computer. I've had some bad experiences with that
Windows
Pentium Dual Core
2046 MB, 3GB
HP w17e
1400x900
Can you get inside the machine and look to see what video card is installed? Switch it off first of course.
Once you have ascertained that then you should uninstall any nVidia drive showing in your Control Panel/Programs/Uninstall a Program and install the latest from nVidia's website.
It's pretty definite that you have an nVidia card from your original post.
Operating System
Win 10 Pro x64 x 2
Alienware ALX x58
2 x 500gb SATA II
1 x 1TB SATA II
(Non-RAID)
Unique
1gb/s up and down
So you're sure I have an nVidia card? That was the kind of card I had before I got it replaced. And also I checked inside but I didn't see a logo of any kind. The only information I could glean was that the fan on the card belonged to Gigabyte.
Windows
Pentium Dual Core
2046 MB, 3GB
HP w17e
1400x900
Well that sys file is definitely an nVidia file, that's the only reason I insist that it's an nVidia problem.
Have you gone into Device Manager and expanded and right-clicked your display adapters & updated the driver and let it search the internet? Has Windows Update perhaps offered a driver (it usually does) and if so did you refuse it - it'll be in hidden updates?
Operating System
Win 10 Pro x64 x 2
Alienware ALX x58
2 x 500gb SATA II
1 x 1TB SATA II
(Non-RAID)
Unique
1gb/s up and down
Yes! I have it I found a model number and now I know that it is an
HP NVIDIA GEFORCE 8300GS 128MB GM304 -69001
Thank you for all of your help.
Windows
Pentium Dual Core
2046 MB, 3GB
HP w17e
1400x900
Operating System
Win 10 Pro x64 x 2
Alienware ALX x58
2 x 500gb SATA II
1 x 1TB SATA II
(Non-RAID)
Unique
1gb/s up and down
I have downloaded the software and am now running with a resolution of 1440 by 900. This is the best display performance my computer has ever had. Thank you very much.
Windows
Pentium Dual Core
2046 MB, 3GB
HP w17e
1400x900
Well that's great. No more error messages I hope?
Operating System
Win 10 Pro x64 x 2
Alienware ALX x58
2 x 500gb SATA II
1 x 1TB SATA II
(Non-RAID)
Unique
1gb/s up and down
