When I put mouse cursor on start button, the start balloon does not show up.
Whenever this happens, my mouse left click does not work properly.
For example, if I click on internet explorer then the it opens however I can't click
anything on explorer. The blue color on top of explorer turns gray and nothing
happens.
When I do ctrl+alt+del to turn on task manager and click couple times on the
task manager screen then it goes back to normal.
Of course first mouse click doesn't work... it is second click on task manager
that will make it work properly.
I know this sounds so strange and unusual. But I'm just trying to explain the
situation as best as possible.
I tried different mouse/ new driver and so on. It has nothing to do with mouse
at all. I just thinking maybe something is running that prevent my mouse from
working properly. I checked virus and adware and everything.
I even format the hard drive more than 5 times but same problem still exists.
Please help.
happens.
Please help.
