Dear Americano,
I think you might of misunderstood what I said. (or other way around)
Let me try to say it again more clearly.
First time when I disable all service I was able to click the start tab. (But only one time). When I immediately reboot, even with all services disable I wasn't able to click the start tab. I reboot many times to see test to see if it would work, but it was only the first time that I was able to click start tab. I tested it twice just right now... but it does not work. So my conclusion is that maybe it is not service or program that is preventing it from being able to use the start tab.
If I was able to click start tab every time all problems are disable, then I can go from one at a time to find out which is causing the problem. But the thing is... even with all disable, the problem still exists. So my thinking is... it must be something else.
If I'm wrong with my logic, then please explain it again for me.
Thank you! Thank you! I really appreciate all your help.
I'm willing to try anything else.
