I need some help with a laptop with Vista unknown specifics, starts in blue screen
boxboyjon
The computer seems to be starting up, a small dos screen flashes in a blink of the eye, and the screen goes blue and stays there. If anyone could help I would appreciate it. Thank you, Jon
It's an HP Pavilion dv4 loaded with Vista Home Premium OEMAct Service pack 1
MilesAhead
Eclectician
Re: I need some help with a laptop with Vista unknown specifics, starts in blue scree
That sounds like what is referred to as a Blue Screen of Death. Please post here instead:
http://www.vistax64.com/crashes-debugging/
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
    750 GB SATA 3G
Prometheus_II
If it's one of those black HP's with silver stripes on it.....well then you have the next problem. Due to overheating it causes the north bridge IC to desolder itself of the heat, it cause the solder to crack and cause a hot spot or dry joint. This in turn gives variouse errors. If you are a little bit technical you can fix it yourself. Look on the net for HP DV graphics problems, the one were you heat the chip up.
    Lenovo y50-70
