I have created a problem... I hope someone can help
Vista Home Premium
HP Notebook Core 2 Duo, 2GB RAM
First I partitioned C to create a partition D for my user data.
Second I went to properties > location of the Documents folder and asked it to move it to D:
But: I did not understand that I should have created a folder within D drive called Documents *before* I moved the target.
I proceeded to move the other folders (pictures, downloads... etc) and discovered then that I needed to make destination folders for them - otherwise it told me it would essentially nest the folders which would clearly be a bad thing.
Moving all the folders worked - but I now have Documents being mapped to D: (at the head of the drive so to speak) and I want to return it to it's original place on C so I can do it again - but properly! (To clarify - I now have Documents targeted to the whole D drive - not a folder in it)
I tried System Restore - but for some reason the only restore point was after moving Documents and before moving the others. I have restored all folders to their original C drive location and everything is as it was - except for the Documents folder - which shows up on the right side of Start menu under user name as "Data Drive (D: )" instead of Documents.
I have also tried to move it back by selecting "restore default" in the location tab of properties. This failed and said "Failed to build the regular list of subfolders under "D:\System volume Information" Access is denied.
If anyone can help I'd be most grateful.
Vista Home Premium
