ICS and DHCP server not working
cnybill
I use a Verizon USB broadband modem attached to my Vista Home Premium desktop using ICS thru a wireless network for internet access and a home network. The desktop is linked to the wireless by CAT5 cable to a regular port on the router. We can then connect my wife's XP and my Linux laptops wirelessly. The router has DHCP disabled and all networked machines get their ip thru ICS from the desktop. This has worked well for 2 years. Suddenly I get limited connectivity from my NIC and a private ip (169.xxx.xx.xx). I looked at the services and found the DHCP server had been stopped. When I tried to restart it as a network service I got an error stating "the account specified for this service is different from other services running in the same process." If I change the logon to Local Service I can restart the service but it still will not give the NIC a valid ip. I have tried to use the diagnose repair option from network and sharing center but it fails as well. Anyone have a suggestion on how to fix this?
    Dell XPS 410
Element
Graphics Freak
Vista Pro
May or may not work but a winsock reset can be helpful in these sort of issues.
1)Click on the Start Button
2)Type "cmd" in the start search area
3)At the top of the menu you see cmd icon, right click it and left click "run as administrator".
4)DOS window, in this window type this minus the quotes " netsh winsock reset "
5)Hit enter key on your keyboard.
6)Restart the computer.
Give this a shot and see if it helps.
    Core 2 Quad Q6600 G0
    Asus P5Q
    8 Gig's OCZ Reaper DDR2-1066
    BFG GTX 275
    OnBoard
    Samsung 216BW 22" LCD Widescreen
    WD 250Gig
    Corsair 850TX
    Antec Nine Hundred
    Razer Death Adder
    Razer Lycosa
    7Meg Cable
cnybill
Thanks for the reply unfortunately it didn't help. When I start the machine it hangs at boot for 30 seconds or so as it tries to start the server but then fails and opens up with an "unidentified network" and a private IP. Begining to think I might have to format and reinstall.
    Dell XPS 410
CrucialHoax
Action is Knowledge
If it worked well for that long something changed. What changed? Any settings, drivers, IP address, anything and everything. List them.
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
