IE7 Print Preview - change print size
yeknomecaps
In IE7 my default print size always starts at "shrink to fit" - I have to change to 100% - when I "X" out and come in again it is again "shrint to fit"
Can anyone tell me how to change the default to be "100%" every time I enter print preview?
Thanks.
judge1974
I think this is controlled by your printer. From the IE7 FAQ page:
" Why do I have to reset the print options every time I open Internet Explorer?
Printing changes made within Internet Explorer are always temporary. To make changes permanently, you need to change them in Windows. For information about changing Windows print options, see Choosing print options."
I didn't see anything in that link particularly useful though ... and when I tried to simply force my printer to print at 100% through the print driver settings, it would always reset itself to Actual Size. Worth a shot for you perhaps, via Properties > Advanced > Printing Defaults > Effects (but that's when using my HP LaserJet 2420 ... will be different depending on make and model of printer, and some printers may not even support this option)
You may need to contact your printer manufacturer if it's bugging you that much, see whether your printer can handle it
    AMD x2 Dual Core 3600+ 1.9GHz
    GigaByte GA-M55SLI-S4
    2GB DDR PC2 5300 RAM
    NVidia GeForce GTS 250 512mb
