IE7 security
brummyfan
Brummy
Hi
When I recieved the warning as per my attachment, I did click on the "allow" but still my IE won't allow the program to run.
I have tried changing the security settings to allow all programs, I have also elevated the UAC level described in the Tutorial.
The page freezes and I am unable to use IE7. Could you please someone help me how to allow the program to run. Thank you in advance.
    Biostar
    Biostar MCP6P-M2
    NVIDIA GeForce 8400GS
    CIBOX
    Hitachi 160GB
Hi Brummyfan,
you need to tell what does the yellow bar state. also what is it trying that your trying to open. please give more infromation so that i could help. the main things u need to check wheter there are any certificate requests when you go to open the file. if so you need to accept it.
hope this helps
Cheers..
Hi John
I am glad to say that I managed to put things right in the end with the help of the Tutorial"Internet Explorer-Reset" by Brink.
My problem was, the faulty add-on(Adobe Shockwave player) and I removed it completely then installed the latest version,now my IE7 works without any problem.
Thank you for your time and effort to help me.:)
    Biostar
    Biostar MCP6P-M2
    CIBOX
    Hitachi 160GB
