Hi, have done a quick search to see if this has been raised before and it doesn't appear so, so here goes...
The other day gmail started complaining that my cache was full so I cleared it and increased the size to 1024MB. This did not stop the error so I looked a little deeper and the issue appears to be that IE7 is not caching anything at all - at least, the "Temporary Internet Files" folder is empty.
This leads me to consider a permissions problem, more so as I have moved the Temp Internet folder to another partition. I have set the permissions on the drive and parent folder to give "everyone" full control. This has not resolved the problem.
Some files have appeared which I think have come from Windows Media Player but websites are not showing up, not even cookies. rss.xml files have also shown up after a reboot from sidebar news gadget (even though it's not running?!).
Is there another user/security principal that requires permission access to the drive/folder?
These symptoms exist on both the 32bit and 64bit versions of IE. I am viewing unencrypted pages even though caching of encrypted pages is enabled. "Check for newer versions of stored pages" is set to automatic.
Thanks for any words of wisdom.
Marv.
p.s. also having trouble reaching this site on my vista machine (having to use XP laptop), I get a DNS error even though the name resolves fine with PING and it won't show this site when using IP address either, is this issue related?
Marv.
- Me
- Core2 Duo E8400 @ 3.0GHz
- Gigabyte EP35DS4
- 8GB Crucial Ballistix PC6400 CL4
- Graphics Card(s)
- ATI Radeon HD 3870 X2
- On board using DTS Connect
- LG-L246WH 24" Widescreen + Acer 17" TFT
1 x 250GB WD SATA1
4 x 500GB Segate 7200.11 SATA2 (RAID5)
- PSU
- Coolermaster 700w modular
- Case
- Coolermaster Cosmos C-1000
- Cooling
- Stock HS & Fan
