Solved IE7 will not go on secure sites
beereycalfs
Vista comes with 2 versions of IE 32 bit and 64 bit right so why does the 64 bit version have no problem going on secure sites and yet 32 bit version refuses to do so normally it would not bother me but my Itunes is using the 32 bit version to go to the store (ithink) and i can not sign on to the store to get my music and yes before anyone suggests i have enabled SSL and TTL
Please help someone !!
Aghibok
firewall?
Imperfect1
Try updating to IE8. It may work on its own, but if not, it has the advantage of the new Compatibility View, and the Compatibility View settings.
    HP Pavillion dv5t (Gen. 1)
    1680 x 1050
    built in - HP
    max
JMH
Banned
Thank you for letting us know - & well done on solving your own problem too.;)
    1440 x 900
    SPECS.
    Drive 1. 298.09 GB Fujitzu MHZ2320BH G2 ATA Device
    Drive 2. [ All as above.]
    CONFIG. C:\287.65 GB, D:\298.09 GB, E:\10.44 GB.
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
