Solved IE8 Google Doodle Not Working
VFN
404
I know this is very minor but it's bothering me and I wonder what's going on. Today's google page has a doodle of basketball that you play a game with. I was using Chrome checking out my Chrome issue, saw it and was able to play, but IE8 doesn't have the button to click to start the game. Anyone with IE8 here able to see the button and animation? Any idea why I'm not able to see and play this?
Here you can play even after today I believe and it doesn't work with IE8 either:
https://www.google.com/doodles/basketball-2012
It may be that these google doodles use HTML 5 canvas which doesn't work with IE8. Can anyone shed more light on this?
Thanks
    Dell Inspiron 546
    Sempron LE-1300
    2GB DDR SDRAM 800MHZ-2X1GB DIM M
    Integrated ATI Radeon HD3200
    VIA High Definition Audio
    Dell m991 17"
    1024 x 768
    320GB NCQ Serial ATA (7200 RPM) w/ 16MB DataBurst Cache
tom982
٩(͡๏̯͡๏)۶
3,642
Location
England
Hi VFN,
Yes, it sounds like a HTML5 compatibility problem :) Is there any reason that you haven't updated to IE9 yet? IE9 has HTML5 support and you'll be able to waste as much time on those doodles as you like (like I do!) :p
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
VFN
404
Thanks for replying. I haven't updated to 9 because I read that a lot people didn't like 9 or had probems with it. If I do update, should I do so through Windows Update--I've got that old IE9 update hidden right now--or another method?
    Dell Inspiron 546
    Sempron LE-1300
    Dell m991 17"
    1024 x 768
tom982
٩(͡๏̯͡๏)۶
3,642
Location
England
Try IE9 and see how it goes. You can always revert back to IE8 if it doesn't work as you expected, or you just don't like it :)
I would do it through Windows Update, because then you're definitely going to get the right version installed.
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
VFN
404
Thanks.
    Dell Inspiron 546
    Sempron LE-1300
    Dell m991 17"
    1024 x 768
