Solved If you are using malwarbytes, antimalware
IF YOU ARE USING MALWARBYTES, ANTIMALWARE do you need to run firewall ??
Malwarebytes
YES!
You should also have an antivirus program. Most of us agree on this type of security package:
Running Windows Firewall, Microsoft Security Essentials, and Malwarebytes.
Those are all free and work great together, without slowing down PC performance.
    AMD/GIGABYTE
    AMD Athlon(tm) 64 X2 Dual Core Processor 6000+ (2 CPUs), ~3.
    Gigabyte GA-M57SLI-S4 (rev. 2.0)
    2048MB RAM
    NVIDIA GeForce 8600 GT
    SyncMaster T220/T220G,SyncMaster Magic T220/T220G(Digital)
    1680 by 1050 pixels
    Seagate ST310003 40AS SCSI Disk Device
    Western Digital WDC WD50 00AAJS-00YFA SCSI Disk Device
    Thermaltake 500W
    VERY FAST>>>>!!!!
    Optiarc DVD RW AD-7191S SCSI CdRom Device
Did you ever fix that JAVA problem, LOL. I believe you had a problem with that in the past? :D
    AMD/GIGABYTE
    2048MB RAM
    1680 by 1050 pixels
    Thermaltake 500W
    VERY FAST>>>>!!!!
in regards to this firewall , i will leave that on i had paid version of spyware doctor but it interfers with a program i run , the 2009 version spyware didnt but this version 2010 does for some reason , i unistalled spyware ran this particullar program ran fine , installed pc spyware doctor again disabled fire wall , still wouldnt work ,....now i have only got malwarebytes running evrything is fine..
so since re-installing pc i have nothing valuable on here anyway ...
oh yes i have fixed that issue , i have a program that runs java of course everytime i open it it sits in task menu (process) tab , i have to go in a nd clear it myself as its like a back door to yahoo ..
so i need to dlete my self out of that window..
One word, LOST?
    AMD/GIGABYTE
    2048MB RAM
    1680 by 1050 pixels
    Thermaltake 500W
    VERY FAST>>>>!!!!
