In Excel 2007, how do I add a column to the left of a column when there is only 3?
A
Advice Pro
I hid all but three columns and if I right-click on column A to insert a column, it becomes column B and no column is to the left.
richc46
Re: In Excel 2007, how do I add a column to the left of a column when there is only 3
I have Excel 2007
I put the cursor in column A, right click, and then insert.
Insert entire column. It appears to the left. Is this what you are doing
A
Advice Pro
That's what I'm doing, but a column doesn't appear. What happens is that the first column becomes column B:
richc46
quite obvious there is a problem, give this a try. Not a fix, but a work around.
Rather than use insert column, try to move everything to the right, then save close and then try insert.
Be sure to get back to me, I am curious to find out if this may be a solution.
townsbg
~~тσωηsвg~~
I get the same thing and that is because all other columns are hidden. If you note when you insert a column A becomes B. If you unhide the columns or you can select B and drag to the left, click unhide and then you see A.
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    N/A
    Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1440 x 900
    1 TB & 360 GB
