Solved infection URL:Mal
calmat
hi everyone
when using chrome i keep getting infection warnings [see attached] i do not get this when using explorer,
how do i stop this.
there are a lot more different ones, i have only picked out three as an example.
richc46
Download Malwarebytes, run a scan
Run a scan, with eset online, no need to download.
Test with virus total. This is actually a test using about 30 antivirus. If you come up negative with all. Avast shows a false positive. Lets see what happens.
Make sure that you are using Chrome when running the scans.
calmat
hi rich
how do i run scans using chrome, i already have malwarebytes in explorer, do i have to download it again using chrome.
can i have this programme in explorer and chrome
how do i run eset online in chrome
regards calmat
richc46
hi rich
regards calmat
I may have misled you. The warning only happens when you are using Chrome. While using Chrome, run a scan with Malwarebytes.
While using Chrome scan with eset.
You do not have Malwarebytes in IE, it is downloaded to your computer.
You can use Chrome and also run a scan with Malwarebytes.
ESET Online Scanner
Just follow the on screen instructions for ESET. It does not need to be downloaded, it is done online.
richc46
I am having a problem explaining properly. Go online, using Chrome. Then, while still online, begin the scan with malwarebytes, the way you usually scan. In my case, I just click on the desktop icon or the icon on the taskbar. How you do it is not important. The malware seems to be connected to Chrome, as per your first post. I am only saying, go online using Chrome and while still online scan using malwarebytes.
The malwarebytes has nothing to do with Chrome, except that you will be online with Chrome during the scan.
americancritic
When online downsize your screen and then have maiwarebytes run a full scan...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
    Processor: AMD Phenom X3 8450 Operating speed: Up to 2.1 GHz, Number of cores: 3, Socket: AM2+, Bus speed: 3600 MHz HT3 (clocked down to 2000 MHz)
    Modem: 56K WinModem/
    Supermulti: 16X DVD(+/-)R/RW 12X Ram (+/-)R DL Lightscribe SATA Drive
    Menory Card Reader: 15-in-1 Multimedia Card Reader
    Media Drive
