Install Home Premium using Ultimate DVD?
showson1
3
Hi all!
First, sorry if this is in the wrong forum.
I just purchased a laptop that has non OS installed and came with no discs, but it does have the license sticker for Vista Home Premium on it.
I purchased Vista Ultimate (32 bit) for my home PC, so I have that DVD.
Is there any option to install Vista Home Premium using the Ultimate DVD?
When I put in the serial number for Home Premium, will it figure out the version from that and let me install it with that DVD, or is it strictly only to install Ultimate?
Hopefully that makes sense and thanks for any info.
14
it should install premium after you put in the serial number
i used my copy of ultimate on a friends computer using their serial number which was premium and it installed with out an issue
    Q6600 Core 2 Quad
    Asus P5NE SLI
    OCZ Platinum XTC 8GB Dual Channel PC6400 Memory - DDR2-800MHz, Enhanced
    SAPPHIRE HD 4870 X2 2G GDDR5 PCI-E
    HP w2207h
    OCZ GameXStream 700-Watt Power Supply
    Ultra Aluminus ATX Full-Tower Case - Black
    Merc Gaming Keyboard
SIW2
2,741
All the dvd's are the same.
It is the product key that determines which Edition is installed.
If the key is stickered on the laptop - you may need to call the oem to activate it.
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
