installed new graphics card sound has gone!!! plz help :S
bunzl
11
Hi All,
I have an Hewlett Packard SR5401UK pc running Vista 32-bit it has onboard graphics & sound but I've just installed an NVIDIA 8800gs graphics card, the card works fine but for some reason the sound has disappeared!! i've just updated the realtek drivers but still have the problem!! it worked fine before installing the g.card , whats even more strange is that when i plug in my headphones i can hear sound but nothing at all through the speakers!!
When i installed the 8800gs it disabled the onboard g.card automatically itself i was wondering if it has done the same with the sound? but if it had i wouldnt be able to hear sound through the headphones right? device manager says the sound is working fine!! :confused: im totally baffled by this if anyone could give me some advice id be grateful!! Thanks for taking time to read this!!
Regards,
Gaz
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Hi Gaz,
Installing a graphics card shouldn't have any effect on your audio. You say that you have no sound through your speakers yet you have when you plug in your headphones. Are you using the rear panel socket for your speakers and the front panel socket for your headphones? Carefully check the wiring to the front panel audio header on your motherboard - it is possible that you have dislodged some of the wires whilst you were installing your graphics card. However, before you do that check the obvious - you are plugging your speakers into the CORRECT socket, aren't you?
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
bunzl
11
Hi dwarf,
I'm using the rear panel sockets for my speakers & the front for my headphones, i have the speakers plugged into the same socket i used before installing the card (worked fine then), it is the correct socket, just looked at the wiring & i cant see any wiring i may have dislodged :confused: its pickled my head this because i know that installing a card should'nt affect the sound.
When i have been plugging the speakers into the sockets on the rear panel the sound occasionally comes on as the jack is halfway into the socket but then goes off when its fully into the socket.
Thanks for your help by the way!! :D
Regards,
Gaz
bunzl
11
Hi Again Dwarf,
I have just read a post from someone else who had the same problem as me, he was told to go into the BIOS on his pc & turn off the onboard graphics card & check the onboard sound is on it worked for him, this is something i havent tried!! the problem is i cant get into my BIOS lol i dont know how to get into it with vista, when i had xp i could access it by pressing F1 or delete on start up, it doesnt work on this pc!! :confused: im new to vista & having some problems gettin used to it!! :o do you know how to access the BIOS?
Regards,
GAZ
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Hi Gaz,
What happens when you plug your headphones into rear panel socket? If you get sound, then it is possible that you have a faulty audio cable from your speakers.
    Gigabyte IF233
bunzl
11
No sound from headphones plugged into rear panel, do you know how to access the BIOS? if pressed everyone of the F top of keyboard esc & del dont work either f**kin hewlett packard grrr
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Hi Gaz,
Your last reply came through just as I was writing my last one. Take a look here - this is the main Technical Support page for your PC: Compaq Presario SR5401UK Desktop PC*
The key you require to enter your BIOS is F10.
    Gigabyte IF233
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
#9
Hi Gaz,
From the Technical Support pages, have a look at the following: Resolving Sound Problems in Windows Vista* (path from earlier link: 'Solve a problem', 'Sound & Microphone', 'Resolving Sound Problems in Windows Vista').
    Gigabyte IF233
