Solved Installing .DWG Viewer
dustydd
I'm trying to install Autodesk DWG Viewer. It says I need to have Microsoft.NET Framework 4 installed. I did this but it doesn't recognize it is installed. How do I get past this?
    DELL 530 inspiron
    Intel core 2cpu 6420 @ 2.13Ghz
    Intel
    2.oo GB
    NVIDIA GeForce 8300GS
    Hi definition audio
    DELL 19" flatscreen
Hm, I havent used the newest autodesk viewer.. I like DWGSee better.
Might give that a try.
Did you read this page? Beyond the Paper: DWG TrueView
    Dual L5639 // i7 950 @ 4.0Ghz
    gtx 560 ti // gtx 260-216
    Dual 22" // Headless
Installed DWGSee & it works fine. Thanks.
ddd
    DELL 530 inspiron
    Intel
    2.oo GB
    Hi definition audio
    DELL 19" flatscreen
