Installs fail at C:\programdata\xxxprogram
Hi
on my Vista home premium SP2 fully updated PC when I try to install any program that writes to the Programdata folder the install fails because it cannot write to the required folder, in the latest incidence the folder was ProgramData\HP\DiditalImaging\Data\Destination\xxxx.dll. the error message is "Make sure you have access to that folder".
I have tried "take Ownership" but that did not work, this PC has only one user and this is a fairly recent problem, it started probably about a year ago, and it is driving me NUTS.
I would appreciate any input and help.
Thanks
Daniel
    Medion Media PC...It's brilliant
townsbg
~~тσωηsвg~~
Make sure that SYSTEM and Administrators has full access to the ProgramData folder folder. Ownership should be SYSTEM or administrators and not a personal ID. My ProgramData folder is owned by administrators. Also On mine CREATOR OWNER also has full access.
    Windows 7 Pro x64
    Mid 2010 iMac
    Quad core 3.2 Ghz Intel I3
    8 gb
    ATI Radeon HD 5670 512 mb ram
    1920x1080 and 1440x900
    1 TB
    N/A
townsbg
~~тσωηsвg~~
Under the security tab where you would take ownership.
    Windows 7 Pro x64
    Mid 2010 iMac
    8 gb
    1 TB
    N/A
