Intel USB 3.0 driver
MountainVista
Hi.
I would like to install this driver. As we all know, Intel do not officially support Vista.
However...as you can see, Server 2008 R2 is supported. Thus, this driver should technically work for Vista SP2.
The obvious problem is that the installer is OS-blocking the driver install. So, my question is to anyone in-the-know; is there a hack that can be implemented in one of the driver files that will allow me to install it?
Thank you :)
ilikefree
What is the chip set you have.
you have not listed it in your system specs
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
townsbg
~~тσωηsвg~~
Windows 2008 r2 is based on 7 not Vista. Neither Vista nor it's server version 2008 are listed as supported OSs. What message are you getting from Vista?
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
erpster4
the Intel USB 3.0 driver setup program will effectively block (prevent) installation under XP & Vista saying the driver is not supported under this OS and quit.
OP has to upgrade to Win7 to install the Intel USB 3.0 driver.
    Windows 7 SP1 Ultimate x64
    4Gb (3.24Gb usable to OS)
    Sigmatel/IDT STAC9200
