Internet browsing help
Hello everyone, I am new to the forums. I am having an issue I recently upgraded my 32 bit vista home basic to 64 bit Vista home premium I am having internet issues. My internet is very slow and I cant browse certain sites for example aol.com or aim.com. I have tried many different things browsing other forums, nothing has worked. I have tried going into my network card advanced config settings, I have tried downloaded 64 bit Vista firefox browser I have re booted my modem and my router. I never had this problem with windows vista 32 bit home basic, it has only started happening now that i have re formatted. I would really appreciate the help, here are my system specs.
AMD Athlon 64 X2 Dual Core Processor 6400+ 3.21 GHz
4G RAM
64 Bit Vista Home Premium
Nvidia 9800 GTX+ Superclocked edition video card
Hitachi 1TB hard drive and another 250gb hard drive
700 watt power supply
My network card is onboard
I dont think i left anything out, I would grealtly appreciate the help, thanks a lot!
brummyfan
Brummy
4G RAM
You could try disabling the "SSV HelperClass" Add-On by going to Tools-> Manage Add-Ons, if that doesn't help try this:Speeding Up Internet Explorer 8 | WindowsFixUp HTH.
4G RAM
Thanks brummyfan, it does seem that your links and advice did help a bit. Though I am still having issues booting up my web browser weather it be Shiretoko ( mozilla 64 bit ) or Internet explorer with the speed ups that your link helped me with. I cannot get my mail at aol.com, it does look better but pages still randomly wont load and loading randomly slows down, if you could give me any more help I would greatly appreciate it, thanks!
This Tutorial may be of some help: http://www.vistax64.com/tutorials/165576-how-make-vista-more-responsive-faster.html?filter[11]=Performance Maintenance
BTW, you could also try uninstalling IE8, stop your Anti-virus program then install IE8 download from here:http://www.microsoft.com/windows/internet-explorer/default.aspx (not from Windows Update), do not forget to enable your Anti-Virus back again. HTH.
Yeah, that sounds good, I reformatted my computer and I installed my motherboard drivers from the CDs that came with my motherboard rather than the internet that seemed to help a bit. I still do have the same issues though, I have 37 more updates for Windows that I need to update. Ill update those now. Before I re formatted I didn't even have an anti virus program so that couldnt have been the issue. Do you think I should un install all of the existing internet explorers I have right now? I have IE 7 and the 64 bit version, thanks!
brummyfan
Brummy
BTW, you could also try uninstalling IE8, stop your Anti-virus program then install IE8 download from here:Internet Explorer 8: Home page (not from Windows Update), do not forget to enable your Anti-Virus back again. HTH.
No, you can't uninstall IE7 because it is part of Windows.
Alright, I have installed all my updates, I am still having this issue to be perfectly specific when I load a page like aol.com or aim.com it will take a long time to load and then the page will come up as a microsoft word page so to speak. The text looks like it was made with microsoft word and so do the links. I have no idea what the problem is and pages still will not load.
Edit: This only happens with Mozilla Firefox 3.5, not the 64 bit version, though it did the same thing on the 64 bit version before I reformatted the second time.
