N nmrm Member Oct 25, 2012 #1 Hi, When I try to start IE9 on my pc it hangs my operating system. What can I do? Regards. My Computer System One
richc46 Vista Guru Gold Member Oct 25, 2012 #2 Welcome Its probably one of the add-ons reset IE Internet Explorer - Reset - Windows 7 Forums My Computer System One Manufacturer/Model Dell XPS420 Memory 6 gig Graphics Card(s) ATI Radeon HD3650 256 MB Sound Card Intergrated 7.1 Channel Audio Monitor(s) Displays Dell SP2009W 20 inch Flat Panel w Webcam Hard Drives 640 gb Cooling Fan Keyboard Dell USB Mouse Dell USB 4 button optical Other Info DSL provided by ATT
N nmrm Member Oct 25, 2012 #3 If I try to run IE9 with no addons, by typing "iexplore -extoff" it hangs. My Computer System One
richc46 Vista Guru Gold Member Oct 25, 2012 #4 For a test, download Firefox and see if it works. If not, its caused by other problems. My Computer System One Manufacturer/Model Dell XPS420 Memory 6 gig Graphics Card(s) ATI Radeon HD3650 256 MB Sound Card Intergrated 7.1 Channel Audio Monitor(s) Displays Dell SP2009W 20 inch Flat Panel w Webcam Hard Drives 640 gb Cooling Fan Keyboard Dell USB Mouse Dell USB 4 button optical Other Info DSL provided by ATT
N nmrm Member Oct 25, 2012 #5 How do you think I posted this message? Firefox works. Downgraded to IE8 and this also works but now I'm back with an hangy-useless IE9. My Computer System One
Madhur B Dell Social Media Team Oct 26, 2012 #6 Hi nmrm, In addition, you can try to run the Microsoft Fix it for IE freezing issues and check if it works. Fix Internet Explorer add-on problems when IE hangs or freezes Also run the Microsoft Fix it for performance issues. Fix Internet Explorer issues to make IE fast, safe and stable Please post back with the results. My Computer System One Manufacturer/Model Custom CPU AMD FX-4100 Motherboard Gigabyte Memory 4Gb Graphics Card(s) ATI 5450 Screen Resolution 1600*900 Internet Speed 10Mbps
N nmrm Member Oct 26, 2012 #7 Those tools don't work, when I click to fix it it says that an unknown error occurred. My Computer System One
A adelejukerberg Member Oct 26, 2012 #8 Same happens with me..... try to reinstall the IE. My Computer System One Manufacturer/Model Dell Inspiron 1550 CPU i3 Processor Memory 3gb Hard Drives 320 Gb
Madhur B Dell Social Media Team Oct 26, 2012 #9 Hi, Go to safe mode with networking and check if IE9 works fine or gives the same problem. Providing the link for detailed instruction: http://www.vistax64.com/tutorials/88009-advanced-boot-options.html Please revert back for clarification. My Computer System One Manufacturer/Model Custom CPU AMD FX-4100 Motherboard Gigabyte Memory 4Gb Graphics Card(s) ATI 5450 Screen Resolution 1600*900 Internet Speed 10Mbps
N nmrm Member Oct 26, 2012 #10 Can't run those tools in safe mode either but I can use IE9 in safe mode with networking, thing that I cannot do on normal mode. As I told, I downgraded to IE8 (this works) and then reinstalled IE9 (stopped working again). My Computer System One
K kinghthood Member Oct 26, 2012 #11 When you are in safe mode disable addons in IE9 How to manage add-ons in Internet Explorer 9 My Computer System One
richc46 Vista Guru Gold Member Oct 26, 2012 #13 This should help Vista and Seven are the Same, in this respect SF IE Restorator - Troubleshooting General Issues with IE - Windows 7 Forums My Computer System One Manufacturer/Model Dell XPS420 Memory 6 gig Graphics Card(s) ATI Radeon HD3650 256 MB Sound Card Intergrated 7.1 Channel Audio Monitor(s) Displays Dell SP2009W 20 inch Flat Panel w Webcam Hard Drives 640 gb Cooling Fan Keyboard Dell USB Mouse Dell USB 4 button optical Other Info DSL provided by ATT
N nmrm Member Oct 27, 2012 #14 Selected all options (except the 32-bit win7 option) but IE9 still doesn't seem to work. My Computer System One
richc46 Vista Guru Gold Member Oct 27, 2012 #15 Create a new user account see if it works there. My Computer System One Manufacturer/Model Dell XPS420 Memory 6 gig Graphics Card(s) ATI Radeon HD3650 256 MB Sound Card Intergrated 7.1 Channel Audio Monitor(s) Displays Dell SP2009W 20 inch Flat Panel w Webcam Hard Drives 640 gb Cooling Fan Keyboard Dell USB Mouse Dell USB 4 button optical Other Info DSL provided by ATT
N nmrm Member Oct 27, 2012 #16 Hi, it works on a new account. It's a step. I wonder what's happening on my main account. My Computer System One
richc46 Vista Guru Gold Member Oct 27, 2012 #17 Its corrupt. See if this fixes it If this does not fix it. You should use the new account. Put your stuff in the new account if you want. http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html My Computer System One Manufacturer/Model Dell XPS420 Memory 6 gig Graphics Card(s) ATI Radeon HD3650 256 MB Sound Card Intergrated 7.1 Channel Audio Monitor(s) Displays Dell SP2009W 20 inch Flat Panel w Webcam Hard Drives 640 gb Cooling Fan Keyboard Dell USB Mouse Dell USB 4 button optical Other Info DSL provided by ATT
N nmrm Member Oct 27, 2012 #18 Ok, I guess now works fine. How do one remove the old profile and related files? Thanks again, Regards. My Computer System One
richc46 Vista Guru Gold Member Oct 27, 2012 #19 You can remove the account with this procedure http://www.vistax64.com/tutorials/93026-user-account-delete.html Im glad that you got your problem sorted. My Computer System One Manufacturer/Model Dell XPS420 Memory 6 gig Graphics Card(s) ATI Radeon HD3650 256 MB Sound Card Intergrated 7.1 Channel Audio Monitor(s) Displays Dell SP2009W 20 inch Flat Panel w Webcam Hard Drives 640 gb Cooling Fan Keyboard Dell USB Mouse Dell USB 4 button optical Other Info DSL provided by ATT
