Solved Invisible icons in notification area (system tray)
terry09
2
I have vista x64 and recently after i cleaned a nasty out of my system, MOST of my notification area icons are invisible. They system icons (network, volume, clock) are showing but the others are not. I have gone in and made sure that i am not hiding inactive icons and far as making sure that I have set all icons to "show". Here is where it get really funked up. I can hover my cursor where the icons should be and it gives me the tips of that program. For example if i hover over where the windows update icon should be, it tells me that i have updates available. And it works. Whilst typing this i thought about changing my theme from vista to classic...the systray had a black box where the icons should be. Kinda like they were being censored but i swear i have no adult rated icons. The system icons still show. I have disabled the UPnP as well as SSDP discovery. I have deleted the registry values of past present and future icons of christmas. That was a joke. I have logged off and logged back on. The only thing that brought them back temporarily was to run ccleaner. After a reboot they went invisible like they were ashamed to be on a windows OS. Go figure. I re-ran ccleaner to no avail. I am now at a loss. I really don't want to reload windows but if i must, i must. Thanks in advance to any suggestions. Oh yeah, sorry for the novel.
jp07764
188
    Gateway
    intel core 2 Extreme QX6700
    intel
    3 gigs
    NVIDA
    Creative SB X-FI
    Gateway 24 HD Monitor
    1920 by 1200 pixels
    2-500 gigabyte hard drive
    Western digtal
terry09
2
Thanks Jimmy for the quick response. Unfortunately I had tried the first suggestion and the second reported nothing. To make matters more (to use a technical term) "jacked up", I have a couple of icons showing now, but when I hover over them, they seem to be in the wrong spot. I.E., I have to hover to the left of my symantec icon to be able to utilize it's properties. Funky huh? Oh well, I will keep trying.
jp07764
188
    Gateway
    intel
    3 gigs
    NVIDA
    Creative SB X-FI
    1920 by 1200 pixels
    Western digtal
crothenb
2
Terry09, did you ever figure out how to fix your issue? I have the same problem left over ofter cleaning up some apparent Trojans. My explorer.exe kept crashing too. All fixed after running 4 different anti-virus/malware programs. But that blacked out section in the Notification Area persists...
-Craig
richc46
Staff member
20,105
Location
Fairfield County, CT
crothenb
2
Thanks for the suggestion. Sorry, I forgot to mention that I did tried that procedures listed above for the reset (merge the provided .reg file and bounce explorer.exe). No luck. BTW, I don't mean to hijack this this thread ;) ... Just wondering if the poster managed to fix his issue in a non destructive way.
Jacee
Security
675
#8
CCleaner has a box to check and clean 'notification cache' ... see if that cleans it up.
    Intel(R) Core(TM)2 Quad CPU
    INTEL/D975XBX2
    ATI Radeon HD 2600 Pro
    Samsung SyncMaster 914v
    1280 x 1024
    2/500GB each ... ST3500630AS ATA Device.
    One is not connected
    Rocketfish 700 W
    G.Skill Gigabyte Chassis
    Microsoft PS/2 Mouse
    DSL
    ATI HDMI Audio
Shadowjk
Network Enthusiast
2,180
Location
Northamptonshire, England
#9
Does this happen with all Users? If you do not have another User than Please Create another one or Enable the Guest Account
Many Thanks,
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
iamzyre
1
#10
Thank you Jacee!! I was having the same problem with the notification area being invisible after a nasty malware removal. I ran the CCleaner and made sure to check the Tray Notification Cache box. Rebooted and now everything is back to normal.
Thanks again :)
Shadowjk
Network Enthusiast
2,180
Location
#11
I'm Glad you got your Problem Sorted I will now mark this thread as Solved ;)
    AMD HD Radeon 6870
    Novatech Night
