In most cases like this, you can't upload an .msc or a .html file - they have to be zipped up in order to upload (as a .zip). Try zipping it up by right clicking on it, selecting "Send to", then selecting "Compressed (zipped) folder"
You only have SP1 installed on Vista. Here's a link to instructions on how to install SP2:
http://windows.microsoft.com/en-us/...-install-Windows-Vista-Service-Pack-2-SP2Some suggestions to ease the installation:
- update all drivers and programs on your system (a major cause of failure to install a Service Pack)
- scan for malware (another major cause of failure to install a Service Pack)
- visit Windows Update and get ALL available updates BEFORE installing SP2
- once SP2 is installed, visit Windows Update repeatedly until there are no more updates available.
You have a NETGEAR WNDA3100v2 N600 Wireless Dual Band USB Adapter. I've seen lot's of issues with these in Win7, but relatively few in Vista. If SP2 doesn't fix the problem, I'd suggest removing the drivers for this device and then installing a fresh copy of the latest available Vista compatible drivers.
You have issues with Microsoft 6to4 adapters. Please open up Device Manager, right click on the problematic 6to4 adapters, and select "Uninstall". If needed, these devices will automatically reinstall when you reboot. BUT, usually they're not needed and don't reappear.
You also have a Nokia 5310 Xpress Music device that's disabled. Please uninstall the software for the device and remove the device from your system. If you need to reinstall it, please be sure to download the latest drivers from the Nokia website.
This suspicious file is in your startups: 0.05009666534566759.exe.lnk
A google search returns no results for it. This is usually a warning sign of a malware infection. Please use a couple of these free scans to ensure that your current protection isn't compromised:
Free Online AntiMalware Resources
Lot's of remnants of Daemon Tools in your dump files. While not usually a problem in Windows Vista, it can become corrupted. Please uninstall it, then use this free tool to remove the sptd.sys driver:
DuplexSecure - FAQ - Remove 64 bit sptd.sys
- Further info on BSOD error messages available at:
http://www.carrona.org/bsodindx.html
- Info on how to troubleshoot BSOD's (DRAFT):
http://www.carrona.org/userbsod.html
- How I do it:
http://www.carrona.org/howidoit.html
The following info is just FYI, I've already addressed the issues that I saw in the above paragraphs
3RD PARTY DRIVERS PRESENT IN THE DUMP FILES
Code:
[font=lucida console]
GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
Lbd.sys Fri Aug 28 05:02:24 2009 (4A979D20)
PS2.sys Thu Sep 07 18:49:03 2006 (4500A1DF)
RTKVHD64.sys Thu Jul 03 04:56:41 2008 (486C9449)
RTKVHD64.sys Wed Feb 11 07:39:19 2009 (4992C6F7)
SECDRV.SYS Wed Sep 13 09:18:38 2006 (4508052E)
Sftfslh.sys Fri Sep 30 12:43:06 2011 (4E85F19A)
Sftplaylh.sys Fri Sep 30 12:43:05 2011 (4E85F199)
Sftredirlh.sys Fri Sep 30 12:43:14 2011 (4E85F1A2)
Sftvollh.sys Fri Sep 30 12:42:46 2011 (4E85F186)
a055kuwz.SYS Wed Dec 03 13:18:47 2008 (4936CD87)
a4lhxlxj.SYS Wed Dec 03 13:18:47 2008 (4936CD87)
a9amo3v9.SYS Wed Dec 03 13:18:47 2008 (4936CD87)
am7c2gbo.SYS Wed Dec 03 13:18:47 2008 (4936CD87)
atikmdag.sys Wed May 14 22:19:05 2008 (482B9D99)
atikmpag.sys Wed Mar 10 17:34:04 2010 (4B981E5C)
atipmdag.sys Wed Mar 10 18:14:05 2010 (4B9827BD)
bcmwlhigh664.sys Thu Mar 31 00:42:08 2011 (4D940620)
bcmwlhigh664.sys Thu Nov 05 19:27:07 2009 (4AF36D5B)
hamachi.sys Thu Feb 19 05:36:41 2009 (499D3639)
mcdbus.sys Tue Feb 24 05:34:07 2009 (49A3CD1F)
nvmfdx64.sys Fri Aug 01 14:38:28 2008 (48935824)
nvmfdx64.sys Wed May 21 13:48:06 2008 (48346056)
nvraid.sys Wed Jun 06 16:34:01 2007 (46671A39)
nvstor64.sys Fri Jun 06 22:08:11 2008 (4849ED8B)
savonaccess.sys Wed Sep 08 12:53:19 2010 (4C87BF7F)
scmndisp.sys Wed Jan 17 02:48:03 2007 (45ADD4B3)
sptd.sys Wed Mar 05 19:34:27 2008 (47CF3C13)
[/font]
Code:
[/font]
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=Lbd.sys
http://www.carrona.org/drivers/driver.php?id=PS2.sys
http://www.carrona.org/drivers/driver.php?id=RTKVHD64.sys
http://www.carrona.org/drivers/driver.php?id=SECDRV.SYS
http://www.carrona.org/drivers/driver.php?id=Sftfslh.sys
http://www.carrona.org/drivers/driver.php?id=Sftplaylh.sys
http://www.carrona.org/drivers/driver.php?id=Sftredirlh.sys
http://www.carrona.org/drivers/driver.php?id=Sftvollh.sys
http://www.carrona.org/drivers/driver.php?id=a055kuwz.SYS
http://www.carrona.org/drivers/driver.php?id=a4lhxlxj.SYS
http://www.carrona.org/drivers/driver.php?id=a9amo3v9.SYS
http://www.carrona.org/drivers/driver.php?id=am7c2gbo.SYS
http://www.carrona.org/drivers/driver.php?id=atikmdag.sys
http://www.carrona.org/drivers/driver.php?id=atikmpag.sys
http://www.carrona.org/drivers/driver.php?id=atipmdag.sys
http://www.carrona.org/drivers/driver.php?id=bcmwlhigh664.sys
http://www.carrona.org/drivers/driver.php?id=hamachi.sys
http://www.carrona.org/drivers/driver.php?id=mcdbus.sys
http://www.carrona.org/drivers/driver.php?id=nvmfdx64.sys
http://www.carrona.org/drivers/driver.php?id=nvraid.sys
http://www.carrona.org/drivers/driver.php?id=nvstor64.sys
http://www.carrona.org/drivers/driver.php?id=savonaccess.sys
http://www.carrona.org/drivers/driver.php?id=scmndisp.sys
http://www.carrona.org/drivers/driver.php?id=sptd.sys
Code:
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini050412-01.dmp]
Built by: 6001.18538.amd64fre.vistasp1_gdr.101014-0432
Debug session time: Fri May 4 06:29:29.167 2012 (UTC - 4:00)
System Uptime: 0 days 0:06:12.867
BugCheck 1E, {ffffffffc0000005, fffff800021323e2, 1, 18}
Probably caused by : ntkrnlmp.exe ( nt!ObpCreateUnnamedHandle+122 )
BUGCHECK_STR: 0x1E_c0000005
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: plugin-containe
FAILURE_BUCKET_ID: X64_0x1E_c0000005_nt!ObpCreateUnnamedHandle+122
Bugcheck code 0000001E
Arguments ffffffff`c0000005 fffff800`021323e2 00000000`00000001 00000000`00000018
BiosVersion = 5.14
BiosReleaseDate = 06/20/2008
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini051712-01.dmp]
Debug session time: Thu May 17 16:33:08.197 2012 (UTC - 4:00)
System Uptime: 0 days 9:59:03.897
BugCheck A, {291f, c, 1, fffff80001e809b6}
Probably caused by : ntkrnlmp.exe ( nt!KeStackAttachProcess+86 )
BUGCHECK_STR: 0xA
PROCESS_NAME: System
FAILURE_BUCKET_ID: X64_0xA_nt!KeStackAttachProcess+86
Bugcheck code 0000000A
Arguments 00000000`0000291f 00000000`0000000c 00000000`00000001 fffff800`01e809b6
BiosVersion = 5.14
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini051712-02.dmp]
Debug session time: Thu May 17 16:53:49.974 2012 (UTC - 4:00)
System Uptime: 0 days 0:01:57.020
BugCheck A, {0, c, 0, fffff80001e8ad25}
Probably caused by : ntkrnlmp.exe ( nt!ExpGetProcessInformation+2b9 )
BUGCHECK_STR: 0xA
PROCESS_NAME: AAWService.exe
FAILURE_BUCKET_ID: X64_0xA_nt!ExpGetProcessInformation+2b9
Arguments 00000000`00000000 00000000`0000000c 00000000`00000000 fffff800`01e8ad25
BiosVersion = 5.14
Loading Dump File [C:\Users\FUBAR\_jcgriff2_\dbug\__Kernel__\Mini051712-03.dmp]
Debug session time: Thu May 17 17:47:43.773 2012 (UTC - 4:00)
System Uptime: 0 days 0:02:41.819
BugCheck A, {7f072, c, 1, fffff80001eb99b6}
BUGCHECK_STR: 0xA
Arguments 00000000`0007f072 00000000`0000000c 00000000`00000001 fffff800`01eb99b6
BiosVersion = 5.14
[/font]
