Is Flash 10 causing IE to freeze, hang and not respond?
stocktiki
20
Posted this in the IE newsgroup. Thought I'd put it here too, and see if anyone has thoughts?
Noticing a rash of users in this forum discuss how IE 7 is suddenly
freezing, not responding or not working in recent weeks. Problem seems
most common on Vista, but appears on XP, too. Getting the same problem
myself on both a Dell desktop and Compaq laptop running Vista SP1.
Problem often appears when using multiple tabs in IE and/or when
closing the IE window. Flash 9 caused freezes too, but it appears more
common with Flash 10. Sometimes the freezes are blatant -- and result
in a pop-up error. Other times the freezes are over in a second or two
-- and you only see the error if you check Vista's Performance
monitoring tools. And it's not just IE. Users are reporting freezes
with other browsers like Firefox and Safari.
For what it's worth, been able to stop the behavior in IE by disabling
Flash. This is done by using Tools>Manage Add-ons>Enable or Disable
Add-ons and highlighting Flash and disabling. If you really need
Flash, you can open a fresh IE window and enable Flash temporarily and
disable it when you're done. Clearly, this is more of a crude
workaround than a solution, since Flash is so common on the Web and
actually required by some Web sites.
This issue is being vigorously discussed at Adobe's online forum,
including here:
Is Flash 10 causing Internet Explorer to freeze and not respond - microsoft.public.internetexplorer.general | Google Groups#
There is still no solution, though. Unfortunately, some users assume
the issue is with IE -- and direct the blame to the incorrect party.
Hopefully this issue can be dealt with. In the meantime, does anyone
know of a better workaround than just enabling Flash when it's
absolutely needed?
Jamdoggy
13
It's an interesting discovery, that Flash 10 is causing such widespread problems with browsers. It seems that these problems are not confined to our own PC's, but are also messing up websites that use Flash, which were otherwise working before.
For example, the popular PhotoBucket site no longer works correctly, and PhotoBucket's admins are trying to 'fix' it: http://forums.photobucket.com/showthread.php?t=30263
Is there any way to 'roll-back' to version 9 until Adobe fix version 10?
Oh, and here is the 'correct' link to the Adobe website discussion (the one in the previous post goes to Google groups, and then has the link there):
http://www.adobe.com/cfusion/webfor...d=44&catid=184&threadid=1401765&enterthread=y
1
I, too, am experiencing the IE 7 lockup problem since installing Flash 10. I have no doubts that this is a Flash problem, not a Vista, XP or Microsoft problem. If I disable Flash 10 in the Add On Manager, the problem goes away. If I re-enable it, I can't follow any links from the page where I start IE. Clicking any link causes IE 7 to hang, and have to be force restarted. Looks as though once again, this burning desire to put out "major revisions" to established software, and force everyone to use the newest by not including backward compatibility has bitten us in the gluteus maximus. How about a little help from Adobe on this? Not forthcoming from what I've seen of their response, which includes the usual finger pointing. When enough people come to realize that Adobe has once again "broken their internet" (to use a term I hear a lot in my tech support job), maybe Adobe will fix their problem or at least come to admit that it is their problem.
Sincerely,
Sick O. Itall
60
AH, so that's what is making IE7 freeze. Thanks for the info.
Brian.
    ME
    AMD 64 X2 5200+
    ASUS M2N-E SLI
    4 GB CORSAIR CM2X 6400 C5 800MHZ
    PNY Geforce 980GTX+ 512MB DDR3
    AUDIGY 2
    ViewSonic VA2216w 22" wide screen
    1680 x 1050
    2 X SAMSUNG SATA 500GB
    1 external usb 500GB
    650 WATT
    IntellieMouse Optical
    Logitech G15
    2mb
75
    HP Pavilion dv5-1110el
    Intel T5800 Core 2 Duo 2GHz
    Quanta 3603
    GeForce 9600M GT (Forceware 189.06)
    Hitachi 2,5" 5400RPM
koch
Power User
94
bellacoup
9
I could not download Flash9 from Adobe. It gave me Flash 10 when I tried. I did get Flash 9 from filehippo, and no more freezes in 2 days. Used to get 1-3 per day.
    HP Model s3700f
    AMD Athlon 64X2 Dual Core Processors 5000+
    3G Ram + 2G ready Boost
    NVIDIA GeForce 615OSE Force430
    Generic PnP (Dell)
    1024X768
    ST 332081 3A5 SCSI Disk Drive
    HP
    HP
    Broadband
