Is OCR "Built-In" to Scanners These Days?
VFN
Have been helping a friend with an HP all in one. I noticed an OCR option on his 8.1 machine, tried it and was able to edit the scanned document. I was trying to fix a scanning issue on his Macbook and I noticed that if I scanned a document and saved it as an RTF it was editable in Mac TextEdit or in Pages (the MSWord of Mac.) At one time it seemed that you had to have specific OCR scanning ability (I've seen hand-held scanners) but does my RTF example show that OCR is "built-in," that scanned texts are all essentially editable now even in PDF if you save as "Searchable PDF"?
Thanks.
    Vista Home Premium x64
    Dell Inspiron 546
    Sempron LE-1300
    2GB DDR SDRAM 800MHZ-2X1GB DIM M
    Integrated ATI Radeon HD3200
    VIA High Definition Audio
    Samsung 32" HDTV
    1366 x 768
    320GB NCQ Serial ATA (7200 RPM) w/ 16MB DataBurst Cache
