is there a ddr2 to ddr3 converter?
Bare Foot Kid
R.I.P. August 13th 2014
Hi chilloh
my brother has a new mobo but it only supports ddr3 and he want to use the ddr2 is it possible?
it only supports ddr3 - You just answered your own question!
Sorry but you will have very bad results if you try!
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
KingOfChaos
The Master of Evil
Vista Pro
What's the difference between DDR2 and DDR3 anyway?
    Velocity Micro, HP Pavillion
    Intel 2 Quad Core Q9400, AMD Athlon 64 x2 4400+
    8 GBs DDR3, 4 GB DDR2 PC5300 (667 MHZ)
    nVIDIA GTS 250 (over clocked), nVIDIA 6150SE n430
    HP w1907
    440 Watts
    Velocity Micro
    Trackman Marble ++
    Logitech G15
    2 mbps
KingOfChaos
The Master of Evil
Vista Pro
That's not what I asked...I asked what the difference between the two are as obviously DDR3 is the next generation.
    HP w1907
    440 Watts
    Velocity Micro
    Trackman Marble ++
    Logitech G15
    2 mbps
joel406
Senior Member
DDR3 is clocked faster then DDR2, but usually has higher latency.
Example: My DDR2 800 Corsair RAM runs at a latency of 4
The counterpart in DDR3 may run at 6 or higher.
There are trade offs between the two. DDR2 runs at 1.8~2.0 volts(core)
DDR3 around 1.4~1.6 volts.
Also DDR2 and DDR3 are keyed differently, so if your MB says DDR3 you will not be able to insert a stick of DDR2 without doing physical damage to your MB.
    My Ever Changing Whim!
    Intel Core 2 Quad 9650
    Intel DQ35JO
    6GB Corsair DDR2 800
    ASUS 9800GT Ultimate
    19 inch Sceptre 19 inch Acer
    1 320GB Seagate SATA
    1 250GB Western Digital SATA
    1 200GB Maxtor SATA
    2x160GB Western Digitals SATA
    1 320GB Seagate External
    1 120GB Western Digital External
    1 80GB Westen Digital External
    1 4GB Crucial Flash Drive for Ready Boost
    600watt Fortron Source
    Antec
    Fresh Air
    Razer Diamondback
    Microsoft Natural Ergonamic 4000
    My main rig runs Vista Ultimate or Server 2008. Depending on which Acronis image I decide to load.
#8
    Intel E6600 @ 3.0 GHz
    EVGA nForce 680i SLI (NF68-A1)
    4GB - CORSAIR XMS2 PC2 6400
    EVGA GeForce 8800 GTS (640MB)
    2 - Seagate Barracuda 7200.10 (320GB)
    1 - Seagate Barracuda 7200.10 (500GB)
Asky
Here to Help
#10
@chilloh Ask your bro to try and replace the MB for a DDR2 one if he hasnt already.
I think even with the converter itll turn out to be expensive and converters arent always reliable especially when you're dealing with RAM Voltages.
If he cannot replace it,its better he goes and buys DDR3 rather than converting .......shud have seen the MB specs before he bought it.
    Intel
    Nvidia 9650M GT
    Asus N80VN-X1 Laptop
    1280 X 800
    1 X 250GB 5200 RPM
    11 MBPS
hatehereyes
Power User
#11
after reading that posted link about the DDR to DDR2 converter..
it seems like it would only work with motherboard chipsets that support both ram types
correct me if i'm wrong people.
    Pentium 4 3.0ghz/ Dual Xeon 2.8ghz 8 cores
    Intel D915GUX
    4gb DDR2 533MHz Memory/4gb DDR2 FB-DIMM
    ATI Radeon x600 Series/ATI Radeon x2600xt
    Dual 19" Gateway FPD1965
    2tb WD
    Velociraptor 300GB WD
    40gb
    Mac Pro - 500gb, 2x 320gb, 150gb
hatehereyes
Power User
#13
if he can afford then just go with the DDR3 memory.
he will be so much more happier with it within the next year or so when more programs utilize the faster memory speeds.
    Intel D915GUX
    2tb WD
    40gb
#14
Hold on. Programs don't have to do anything special to "utilize" the faster memory speeds. Programs don't check for the type of memory installed. Faster memory is faster memory. Faster memory is automatically utilized by software just like faster CPU's are. So the "within the next year or so" comment makes no sense and is false.
S-
hatehereyes
Power User
#15
wouldn't it make sense though?
like how having more memory and faster memory, programs would load faster?
    Intel D915GUX
    2tb WD
    40gb
#16
What you said made no sense.
S-
hatehereyes
Power User
#17
ok then tell me how it didn't make sense?
what would be the point of there being different speeds of memory if it didn't affect the speed of the computer?
and what is the point of upgrading memory from DDR to DDR2 if DDR3 if there wasn't a difference between them?
    Intel D915GUX
    2tb WD
    40gb
#18
But that is not what you said. Here it is again:
"he will be so much more happier with it within the next year or so when more programs utilize the faster memory speeds."
Look at your words. You say that "within the next year or so when more programs utilize the faster memory speeds."
My comments were directed at your text that said more programs would utilize the faster memory speeds in the next year or so.
Again, programs don't have to do anything special to "utilize" the faster memory speeds. Programs don't check for the type of memory installed. Faster memory is faster memory. Faster memory is automatically utilized by software just like faster CPU's are. So the "within the next year or so" comment makes no sense and is false.
S-
hatehereyes
Power User
#19
alright well i guess.
my mistake then.
    Intel D915GUX
    2tb WD
    40gb
